I just finished the initial gnu++0x compatibility edits/fixes in RIOT for the native port.
I've tested the changes with the default-native project.
I've checked if using g++0x with g++ and gnu99 with gcc compiles and works. (it does )
Though I cannot tell if the changes have other unforeseen negative effects especially for the real boards. I will send a pull request, so if anyone is concerned about the changes please discard it.
BTW. to use the g++0x and g++ some edits in the default-native project and the native board have to be done. I will fork the boards and projects today and add the necessary changes.
Best regards, Martin
