What are the drawbacks of using a hardware timer with only a 32.768
kHz tick rate?
Would there be any problems with scheduling or hardware drivers when
using a lower timer frequency?
What is the side effect of assigning the hwtimer module only one
hardware timer channel?
As I understand from the code, the hwtimer module uses some kind of
internal queue to be able to handle more timers than there are
hardware channels, is this correct?
On our platform we are using the Freescale Kinetis K60 which has only
one timer (LPTMR) which can wake the CPU from deep sleep. We need to
use deep sleep in order to reduce power consumption in power
constrained situations (battery powered etc.). All other timer modules
in the CPU are halted when the CPU enters a deep sleep mode.
Joakim Gebart
Managing Director
Eistec AB
kHz tick rate?
That shouldn't pose a problem with most peripherals. 30us should be fine.
Also that's ok.
Exactly. hwtimer is essentially a multiplexer for (usually limited) real timer hardware.
That sounds very interesting!
We're a little behind on supporting deep sleep modes, but if your hardware timer interrupt is able to wake up the MCU, you should check out the lpm_set code and the idle thread.
Ideally, the idle thread puts your MCU into the deepest possible mode using lpm_set as soon as nothing else is to do.
