I have a “LILYGO T-Dongle-S3” ESP32S3 module (“no LCD” variant). I’m able to compile basic examples using PlatformIO and the espidf framework using these platformio.ini settings:
[env:esp32-s3-devkitc-1]
platform = espressif32
board = esp32-s3-devkitc-1
framework = espidf
This module has a single USB port that shows up as the Espressif USB JTAG/serial device on /dev/ttyACM0 when I plug it in, and I’m able to see the console output from the various PlatformIO/espidf examples I’ve tried when I open the serial console on /dev/ttyACM0 with picocom.
However, I’m not able to get any output when trying the RIOT OS examples.
I’m able to build and upload the hello-world example. I’m using BOARD=esp32s3-devkit since that seems to be identical to the esp32-s3-devkitc-1 board that worked with PlatformIO. Here is the output from building and flashing the RIOT OS hello-world example:
edmonds@chase{0}:~/src/RIOT$ BUILD_IN_DOCKER=1 DOCKER=podman BOARD=esp32s3-devkit PORT=/dev/ttyACM0 make -C examples/hello-world clean
make: Entering directory '/home/edmonds/src/RIOT/examples/hello-world'
rm -rf /home/edmonds/src/RIOT/examples/hello-world/bin/esp32s3-devkit/pkg-build/esp32_sdk
make: Leaving directory '/home/edmonds/src/RIOT/examples/hello-world'
edmonds@chase{0}:~/src/RIOT$ BUILD_IN_DOCKER=1 DOCKER=podman BOARD=esp32s3-devkit PORT=/dev/ttyACM0 make -C examples/hello-world flash
Launching build container using image "sha256:1329f419ec1a045a5830361f288536a56a0671a3b0db216e469369b00719cdff".
podman run --rm --tty --userns keep-id -v '/usr/share/zoneinfo/America/New_York:/etc/localtime:ro' -v '/home/edmonds/src/RIOT:/data/riotbuild/riotbase:delegated' -v '/home/edmonds/.cargo/registry:/data/riotbuild/.cargo/registry:delegated' -v '/home/edmonds/.cargo/git:/data/riotbuild/.cargo/git:delegated' -e 'RIOTBASE=/data/riotbuild/riotbase' -e 'CCACHE_BASEDIR=/data/riotbuild/riotbase' -e 'BUILD_DIR=/data/riotbuild/riotbase/build' -e 'BUILD_IN_DOCKER=/data/riotbuild/riotbase/examples/hello-world/1' -e 'RIOTPROJECT=/data/riotbuild/riotbase' -e 'RIOTCPU=/data/riotbuild/riotbase/cpu' -e 'RIOTBOARD=/data/riotbuild/riotbase/boards' -e 'RIOTMAKE=/data/riotbuild/riotbase/makefiles' -e 'BOARD=esp32s3-devkit' -e 'DISABLE_MODULE=' -e 'DEFAULT_MODULE=' -e 'FEATURES_REQUIRED=' -e 'FEATURES_BLACKLIST=' -e 'FEATURES_OPTIONAL=' -e 'USEMODULE=' -e 'USEPKG=' -w '/data/riotbuild/riotbase/examples/hello-world/' 'sha256:1329f419ec1a045a5830361f288536a56a0671a3b0db216e469369b00719cdff' make
Building application "hello-world" for "esp32s3-devkit" with CPU "esp32".
"make" -C /data/riotbuild/riotbase/pkg/esp32_sdk/
"make" -C /data/riotbuild/riotbase/boards/common/init
"make" -C /data/riotbuild/riotbase/boards/esp32s3-devkit
"make" -C /data/riotbuild/riotbase/boards/common/esp32s3
"make" -C /data/riotbuild/riotbase/boards/common/esp32x
"make" -C /data/riotbuild/riotbase/core
"make" -C /data/riotbuild/riotbase/core/lib
"make" -C /data/riotbuild/riotbase/cpu/esp32
"make" -C /data/riotbuild/riotbase/cpu/esp32/bootloader
esptool.py v3.2-dev
Merged 1 ELF section
"make" -C /data/riotbuild/riotbase/cpu/esp32/esp-idf
"make" -C /data/riotbuild/riotbase/cpu/esp32/esp-idf/common
"make" -C /data/riotbuild/riotbase/cpu/esp32/esp-idf/efuse
"make" -C /data/riotbuild/riotbase/cpu/esp32/esp-idf/gpio
"make" -C /data/riotbuild/riotbase/cpu/esp32/esp-idf-api
"make" -C /data/riotbuild/riotbase/cpu/esp32/freertos
"make" -C /data/riotbuild/riotbase/cpu/esp32/periph
"make" -C /data/riotbuild/riotbase/cpu/esp_common
"make" -C /data/riotbuild/riotbase/cpu/esp_common/esp-xtensa
"make" -C /data/riotbuild/riotbase/cpu/esp_common/freertos
"make" -C /data/riotbuild/riotbase/cpu/esp_common/periph
"make" -C /data/riotbuild/riotbase/cpu/esp_common/vendor
"make" -C /data/riotbuild/riotbase/cpu/esp_common/vendor/xtensa
"make" -C /data/riotbuild/riotbase/drivers
"make" -C /data/riotbuild/riotbase/drivers/periph_common
"make" -C /data/riotbuild/riotbase/sys
"make" -C /data/riotbuild/riotbase/sys/auto_init
"make" -C /data/riotbuild/riotbase/sys/div
"make" -C /data/riotbuild/riotbase/sys/libc
"make" -C /data/riotbuild/riotbase/sys/luid
"make" -C /data/riotbuild/riotbase/sys/newlib_syscalls_default
"make" -C /data/riotbuild/riotbase/sys/pm_layered
"make" -C /data/riotbuild/riotbase/sys/preprocessor
"make" -C /data/riotbuild/riotbase/sys/random
"make" -C /data/riotbuild/riotbase/sys/stdio
"make" -C /data/riotbuild/riotbase/sys/stdio_uart
esptool.py v3.2-dev
Merged 2 ELF sections
Parsing CSV input...
59358 11200 75406 145964 23a2c /data/riotbuild/riotbase/examples/hello-world/bin/esp32s3-devkit/hello-world.elf
/home/edmonds/src/RIOT/dist/tools/esptools/esptool_v3.2.py --chip esp32s3 --port /dev/ttyACM0 --baud 460800 --before default_reset write_flash -z --flash_mode dio --flash_freq 80m --flash_size detect 0x0000 /home/edmonds/src/RIOT/examples/hello-world/bin/esp32s3-devkit/esp_bootloader/bootloader.bin 0x8000 /home/edmonds/src/RIOT/examples/hello-world/bin/esp32s3-devkit/partitions.bin 0x10000 /home/edmonds/src/RIOT/examples/hello-world/bin/esp32s3-devkit/hello-world.elf.bin
esptool.py v3.2-dev
Serial port /dev/ttyACM0
Connecting....
Chip is ESP32-S3
Features: WiFi, BLE
Crystal is 40MHz
MAC: f4:12:fa:af:6a:ec
Uploading stub...
Running stub...
Stub running...
Changing baud rate to 460800
Changed.
Configuring flash size...
Auto-detected Flash size: 16MB
Flash will be erased from 0x00000000 to 0x00003fff...
Flash will be erased from 0x00008000 to 0x00008fff...
Flash will be erased from 0x00010000 to 0x00029fff...
Compressed 14480 bytes to 9756...
Wrote 14480 bytes (9756 compressed) at 0x00000000 in 0.3 seconds (effective 414.3 kbit/s)...
Hash of data verified.
Compressed 3072 bytes to 85...
Wrote 3072 bytes (85 compressed) at 0x00008000 in 0.1 seconds (effective 371.3 kbit/s)...
Compressed 105648 bytes to 45529...
Wrote 105648 bytes (45529 compressed) at 0x00010000 in 1.2 seconds (effective 729.2 kbit/s)...
Leaving...
Hard resetting via RTS pin...
Then, I unplug and re-plug the ESP32S3 from the USB port.
Then, I open picocom on /dev/ttyACM0.
Then, I run make reset from the RIOT OS source tree and watch the terminal.
edmonds@chase{0}:~/src/RIOT$ BUILD_IN_DOCKER=1 DOCKER=podman BOARD=esp32s3-devkit PORT=/dev/ttyACM0 make -C examples/hello-world reset
/home/edmonds/src/RIOT/dist/tools/esptools/espreset.py --port /dev/ttyACM0
And I see the following output on the terminal:
ESP-ROM:esp32s3-20210327
Build:Mar 27 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0x8 (SPI_FAST_FLASH_BOOT)
Saved PC:0x420034af
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd0108,len:0x494
load:0x403b6000,len:0x4
load:0x403b6004,len:0x2d40
load:0x403ba000,len:0x650
entry 0x403b600c
Pro cpu up.
Single core mode
OK, so when I ran make reset I saw some output that appears to be from the boot loader, but nothing else. Where is the output from the hello-world example that is supposed to be printed?
int main(void)
puts("Hello World!");
printf("You are running RIOT on a(n) %s board.\n", RIOT_BOARD);
printf("This board features a(n) %s CPU.\n", RIOT_CPU);
return 0;
Thanks!
