As per the documentation(), which says that:
TLSF-based global memory allocator.
This is a malloc/free implementation built on top of the TLSF
allocator. It defines a global tlsf_control block and performs
allocations on that block. This implementation replaces the system
malloc
Additionally, the calls to TLSF are wrapped in
irq_disable()/irq_restore(), to make it thread-safe.
My question is how to comprehend this:
the calls to TLSF are wrapped in irq_disable()/irq_restore(), to make
it thread-safe.
Thank you for your attention to this matter.
Best Regards.
Sunshilong
RIOT is currently only running on single core platforms. Any context switch
needs to be triggered either by the running thread (e.g. `thread_yield()`,
`mutex_lock()`, `msg_receive()`, or ...), or from an interrupt service routine
(ISR). The first is not a problem when protecting malloc data structures: No
programmer will ever (at least intentionally) trigger a context switch while a
data structure is in an inconsistent state.
IRQs however can come in at any point in time, thus e.g. while an operation on
a data structure is still in progress and the data structure in question is in
an inconsistent state. If that data structure is touched externally while in
inconsistent state, bad things will happen. This could either happen in the
ISR, but also in a thread that gets scheduled after the ISR (e.g. because the
ISR unblocks a higher priority thread).
A call to `irq_disable()` will result in the corresponding ISRs of any incoming
IRQs to not be executed immediately. Instead, those will be delayed until after
a matching call to `irq_disable()`. By wrapping access to shared data
structures into a pair of `irq_disable()` and `irq_restore()`, it is guaranteed
that no ISRs will trigger while the data structures are in an inconsistent
state.
(One detail: If `irq_disable()` is called n times, IRQs will only be enabled
after calling n matching `irq_restore()`. So it is totally safe to call
`irq_disable()` while IRQs are already disabled. We only need to take great
care that for every `irq_disable()` there is exactly one matching
`irq_restore()`.)
So for the TLSF-based memory allocator, just this approach is used to prevent
other threads (or ISRs) to touch the allocator data structures while they are
Kind regards,
Marian
