As you said, bridging two different link layer protocols together is not going to work. These don’t mix. You’re going to have to connect them by routing traffic. There is not much of a tutorial on the RIOT wiki on this, but generic routing tutorials for this should work fine. Mostly what you need is to tell nodes on both side that they can reach each other via your Linux host. A default route pointing to the Linux host should do fine in most cases and especially if the Linux host is the gateway to the internet anyway. The other thing is to tell your Linux host how to reach both nodes and that it is allowed to forward traffic between the two interfaces.
For this to work both the IPv6-over-BLE need their own routable IPv6 range. Either take blocks from the range you already have, or generate two unique ULA ranges, or for development setups take two subnets from the 2001:db8::/32
range.
One should be used on the bl0
interface for the IPv6-over-BLE range and one on the tapbr0
device (just guessing interface names here). Both ranges should show up in ip -6 route
on Linux. Make sure that you can ping devices on either side from Linux to confirm that you have connectivity from Linux to the devices.
Forwarding packets from one subnet to the other can be enabled with:
sysctl -w net.ipv6.conf.all.forwarding=1
(please note that this usually causes Linux to stop responding to router advertisements)
Make sure that any firewall active on the Pi has rules to allow traffic between the two interfaces. Something along the lines of (but please check to make sure) makes Linux allow traffic flow between the two interfaces:
ip6tables -A FORWARD -i bt0 -o tapbr0 -j ACCEPT
ip6tables -A FORWARD -o bt0 -i tapbr0 -j ACCEPT
Last thing is to check if the RIOT nodes themselves know that they can reach the other subnet via the Linux host. For test setups you can manually add a route on them with the nib route
shell command:
> nib route add $interface_id $other_subnet $linux_address
For example:
> nib route add 7 2001:db8:0:2::/64 2001:db8:0:1::1
I think this should cover everything needed to route traffic between the instances. As this is all from the top of my head please let me know if this indeed works for you or if you have any further questions.
