Hello all,
I have recently started using Riot and it would be extremely helpful if there was a brief tutorial explaining how the scheduler is working. I have read the documentation on the website and also some papers published on this topic. However, the only information I have managed to get is that the scheduler is a tickles scheduler and that the threads can be assigned priorities. What I would like to know is
How and when the scheduler runs a thread with higher priority if a thread with lower priority is currently running.
If no threads are running then how does the scheduler check if new threads need to start.
Thanks,
Abhinav
Hi Abhinav,
Thanks for the input, I guess we really need proper documentation
there. I'm volunteering to write it.
1) How and when the scheduler runs a thread with higher priority if
Whenever an interrupt or blocking operation occurs AND the thread with
the higher priority is runnable. I.e. the high priority thread becomes
unblocked.
2) If no threads are running then how does the scheduler check if
Not sure if I get your question, but:
- New threads are only created by explicit calls to thread_create
- Whether a thread is runnable depends on its blocking calls
- At least the idle thread will always be runnable
- Interrupts trigger scheduler runs
Cheers, Ludwig
Hi Ludwig, hi Abhinav!
Indeed a good idea, thanks for the suggestion. And thanks for volunteering,
Ludwig. It's appreciated!
As Ludwig wrote, if nothing else has to be done, the IDLE thread will run
(putting the µc into deep sleep mode). It won't be interrupt until an hardware
IRQ (radio packet received, timer fired, user input over USART, sensor device
triggers...) occurs.
Oleg
Hello Ludwig,
Thank you for volunteering to write the tutorial - I think it would be
very helpful because it is very difficult to debug programs unless I
understand what the scheduler is doing.
I think I partially understand your answers. Am I right in assuming that
1) The scheduler runs only if an interrupt occurs and/or the currently
running thread enters a blocking operation and
2) When the scheduler runs it then picks a runnable thread with the
highest priority.
Does the scheduler get triggered on every interrupt?
Thanks,
Abhinav
... or any function that might make another thread runnable, e.g., sending a message or releasing a mutex.
highest priority.
Correct.
Nope. The ISR has to set a flag (sched_context_switch_request) which will happen automatically on kernel functions that might trigger a context switch.
Thanks Kasper.
Suppose there are three threads A, B and C with priorities A > B > C.
Also suppose all three threads are currently runnable and the therefore
the scheduler is currently running thread A. If thread A sends a message
to thread C then immediately after calling the message passing function,
which thread does the scheduler execute? Will it continue to execute
thread A till it gets blocked and then run thread B till it gets blocked
and then finally run thread C?
Abhinav
Is the same also true if creating a new thread? i.e.
Suppose there are two threads A and B with priorities A > B. Also
suppose all both threads are currently runnable and therefore the
scheduler is currently running thread A. If thread A creates a new
thread C with priority A>B>C, which thread does the scheduler execute?
Will it continue to execute thread A till it gets blocked and then run
thread B till it gets blocked and then finally run thread C?
Thanks,
Abhinav
Okay!
Thanks a lot Kasper.
Abhinav
Hi Abhinav,
Yes.
You could also experiment by modifying and running (e.g. with native):
https://gist.github.com/LudwigOrtmann/7fd2dab7aa91e801b05e
Interesting operations for you:
- `thread_yield`:
Do a voluntary context switch.
The thread remains runnable and will be immediately scheduled
again if there is no other runnable thread with a priority at
least equal to it.
- `thread_sleep`
Do a voluntary "blocking" operation. Thread needs to woken again
using:
- `thread_wakup`
Wake and possibly run sleeping thread again. I.e. "unblock".
Cheers, Ludwig
