How do ISRs work in the context of RIOT's scheduler?
I’m rather new to using RIOT and have been hunting around for some thorough documentation on how the scheduler works, but haven’t really been able to find anything that helps to explain what I am generally seeing in most ISR definitions, which tend to end with the following bit of code:
if (sched_context_switch_request) { thread_yield(); }
My first questions are: What are the general sources for context switch requests and what does it mean to call thread_yield in an ISR? I would have imagined that ISRs are called outside of the context of any thread, so calling yield within them didn’t immediately make sense to me. Is this just a general pattern for triggering the scheduler to run, if necessary, after the ISR has completed?
I walked through the code in thread_yield a bit and (for the Cortex-M platform specifically) reached this partial understanding:
void thread_yield(void) { // Disable IRQs and store the PRIMASK unsigned old_state = irq_disable();
// Get the currently active thread (In an ISR, I assume this is the interrupted thread) thread_t *me = (thread_t *)sched_active_thread;
// If the thread is currently running or pending if (me->status >= STATUS_ON_RUNQUEUE) { // Advance the next runnable thread at the current thread’s priority level clist_lpoprpush(&sched_runqueues[me->priority]); }
// Re-enable the original PRIMASK irq_restore(old_state);
// Trigger the PendSV interrupt to run the scheduler thread_yield_higher(); }
I’m having a bit of difficulty understanding the flow of events that would lead you to call thread_yield inside of an ISR, as I imagine that it causes the thread that was running before the ISR was executed to be the one that yields. Why would it be necessary to cause that thread to yield to other threads at the same level of priority simply because a potentially unrelated ISR was run? I predict that the reasoning for that is explained by how sched_context_switch_request operates.
Perhaps this is designed for the case where actions are taken inside the ISR which signal other threads (like sending IPC messages), but I’m still not clear on why it would need to reschedule the previously executing thread relative to other running or pending threads of equal priority.
Any clarification or direction towards more indepth documentation of the scheduling system is much appreciated.
Thanks much, Charles
Hi Charles,
Perhaps this is designed for the case where actions are taken inside the ISR which signal other threads (like sending IPC messages), but I'm still not clear on why it would need to reschedule the previously executing thread relative to other running or pending threads of equal priority.
Your analysis is correct, and you might have found a bug in the scheduling logic. "sched_context_switch_request" is used by "context-switch triggering" functions (sending a message, unblocking a mutex), so after the ISR ends, the context switching code runs the scheduler and then switches to the highest priority thread in pending state. It should not advance the circular list of the current thread. Threads in one priority level are supposed to be scheduled cooperatively.
So in essence, "thread_yield_higher()" should be called instead of "thread_yield()".
I'll investigate some more and then probably fix this.
Thanks for digging this deep!
Hi Kaspar!
> Perhaps this is designed for the case where actions are taken inside the > ISR which signal other threads (like sending IPC messages), but I'm > still not clear on why it would need to reschedule the previously > executing thread relative to other running or pending threads of equal > priority.
I would call it rather a bug in the documentation. The behavior of the scheduler for threads of the same priority is simply underspecified. The only thing the API says here is:
"Assigning the same priority to two or more threads is usually not a good idea. A thread in RIOT may run until it yields (thread_yield) or another thread with higher priority is runnable (STATUS_ON_RUNQUEUE) again. Multiple threads with the same priority will therefore be scheduled cooperatively: when one of them is running, all others with the same priority depend on it to yield (or be interrupted by a thread with higher priority). This may make it difficult to determine when which of them gets scheduled and how much CPU time they will get. In most applications, the number of threads in application is significantly smaller than the number of available priorities, so assigning distinct priorities per thread should not be a problem. Only assign the same priority to multiple threads if you know what you are doing!" [Source: https://riot-os.org/api/group__core__thread.html]
Hence, if we change the scheduler and update the documentation accordingly, we should also make sure that the pointer in the list of threads with equal priority is not advanced if a thread gets interrupted by a thread with a higher priority, either. I.e., the pointer should only be advanced if a thread explicitly calls `thread_yield()`.
We had that discussion offline. The "bug" is both in Cortex-M's ISR handling and in the docs.
This last half sentence (in braces) is wrong. A higher thread might interrupt one with "siblings" of the same priority, but after the high-prio thread is done, the scheduler would switch back to the initial thread.
We should re-word the whole paragraph.
That is already the case. thread_yield() advances the current priority's circular list, then calls thread_yield_higher(). But the ISR handling should directly call thread_yield_higher() instead of thread_yield(), as Charles pointed out.
Hi Kaspar!
> I would call it rather a bug in the documentation. The behavior of the > scheduler for threads of the same priority is simply underspecified.
Okay, re-reading the documentation again, I agree that the behavior deviates from what is written. I also see, that the behavior is indeed different on different architectures which is clearly a bug.
> "Assigning the same priority to two or more threads is usually not a good > idea. A thread in RIOT may run until it yields (thread_yield) or another > thread with higher priority is runnable (STATUS_ON_RUNQUEUE) again. Multiple > threads with the same priority will therefore be scheduled cooperatively: when > one of them is running, all others with the same priority depend on it to > yield (or be interrupted by a thread with higher priority).
That's probably my fault. I always thought that `sched_run()` would advance the pointer which is apparently not true.
Hi Kaspar!
