Hi there!
I’ve tried to send ip/udp periodic message from remote node by sock API:
code
void* ip_handler(void *arg){
(void)arg;
sock_ip_ep_t remote = { .family = AF_INET6 };
ssize_t res;
ipv6_addr_from_str((ipv6_addr_t*)&remote.addr.ipv6,"fd00:dead:beef::1");
while (1) {
char text[127];
sprintf(text, "payload");
res = sock_ip_send(NULL, text, strlen(text), PROTNUM_IPV6_EXT_HOPOPT, &remote);
if (res < 0) {
printf("Error sending reply = %d\n", res);
ztimer_sleep(ZTIMER_MSEC, 2000);
return NULL;
So it work pretty well along with gnrc_border_router + ethos. But when I set off the BR, the node had stopped sending a message without any errors after some time. Should I use raw netapi for solving this problem?
