why would you want to change the router solicitation interval
(RTR_SOLICITATION_INTERVAL) outside the scope foreseen by the RFC?
It’s not really that i wan’t to change the interval. The thing is my node goes into deep sleep and to be battery efficient I need Router Solicitation Messages to go out as soon as it wakes up, which is not happening with gnrc default set-up. That’s why I was asking how I can trigger one in the cleanest way. Cheers,
It's not really that i wan't to change the interval. The thing is my node goes into deep sleep and to be battery efficient I need Router Solicitation Messages to go out as soon as it wakes up, which is not happening with gnrc default set-up. That's why I was asking how I can trigger one in the cleanest way. Cheers,
Actually, you shouldn't need to trigger a RS explicitly. This should happen
automatically within RIOT, i.e., send an RS whenever a link gets ready, which
also applies to wake up from sleep. Hence, (IMHO) this needs to be fixed in
the network stack.
@miri64 might know the right place? Anyhow, if not already done: please open
an issue addressing and describing this issue, so we have it officially and
trackable.
to be more explicit: a Router Solicitation Messages should be sent out immediately after a link comes up. This usually happens by link triggers from the interface.
