I’m trying to play with the RIOT shell console and networking starting from the gnrc_border_router sample.
I plugged the openmote device through USB to the Ubuntu machine, but when i try to run the RIOT shell (on the mote) with pyterm, it shows me :
"RIOT border router example application "
“All up, running the shell now”
but i can’t enter any command because the shell doesn’t respond.
If instead i build the project as “native” it works perfectly.
There is a quick solution?
thanks a lot and BR,
Alessandro
Hi Alessandro,
have you checked out the README? You have to run the gnrc_border_router
example with the dist/tools/ethos/start_network.sh
script, since it parallelises stdio and network traffic over the same UART. With pyterm your input might be interpreted as network packets.
Martine
Hi Martine,## I am unable to ping gnrc_border_router using Zolertia RE-Mote.
Following is the output of my system terminal.
Hi Suman,
seems my mail on users didn’t get to you, since I used the wrong mail address to send it from. Well then let me paste my answer here too:
looks like you only got the ethos interface running. Did you include and configure the radio driver (question to the list: is the radio driver for the cc2538 already merged yet, wasn’t able to find it :/)? Nevertheless you should be able to ping the ethos interface. Try ping6 -I tap0 fe80::202:f8ff:fe70:f121
or ping6 fe80::202:f8ff:fe70:f121%tap0
(depends on your ping6 version) on your Linux machine.
Martine
Thanks Martine.
Now I am able to ping border router from Linux system. Before I was trying to ping global ipv6 address 2001:db8::202:f8ff:fe70:f121. Just would like to know that when boarder router gets global ipv6 address.
