i have a network setup with a RIOT-node configured as a coap-server and a Linux host as the client. The client uses a python3 script adapted from the aiocoap-package examples. This setup works properly.
As I would like to access the coap server from an http client, I tried to use the aiocoap proxy server. This failed so far, e.g. .
~$ aiocoap-proxy --forward --reverse --server-address [fc00::2:xyz] --server-port 5684
leads to an error message “… socket.gaierror: [Errno -2] Name or service not known”
I tried several variations of the aiocope-proxy command without success.
Does anybody know how to use the aiocoap-proxy command? Could you give me a working example? Thanks in advance.
Best regards, Raimund
