The forum will go into read-only for a migration to a more stable environment. This means that it won’t be possible to reply or post to any topic for the time.
We expect that the migration will take at most 1 hour. It is likely that the forum will also be not responsive for a bit somewhere in between, but we will try our best to minimize the actual down time.
Thank you for your patience
bergzand
Made this a banner . It will appear at the top of every page until it is dismissed by the user.
#2
And done.
Migration happened successfully with some down time in between due to a discourse docker yaml config not properly being applied to the generated docker image, but otherwise nothing severe.
bergzand
Removed this banner . It will no longer appear at the top of every page.
#4
Just checking that the mail forwarder works in both directions…
On Mon, Feb 06, 2023 at 02:16:20PM +0000, Koen Zandberg via RIOT wrote:
And done.
(okay, goes through a tunnel back to Canada, and then back across the ocean
again…)
