Hello guys,
I face a build error problem when I try to build the hello-world example for native.
I work on Ubuntu 22.04.5 LTS over WSL.
Thanks
Hello guys,
Thanks
Hej and welcome to the RIOT community!
I assume that you’ve followed the tutorial at RIOT/doc/guides/setup-windows at master · RIOT-OS/RIOT · GitHub to setup your development environment with WSL. If not, please double-check that you have installed all required packages with sudo apt install ....
Could you paste the output of uname -srv and file /home/evyatarv/RIOT/examples/hello-world/bin/native/hello-world.elf in the Ubuntu shell here?
Does it work if you specify BOARD=native64 on your build command line?
great, it works. ![]()
Thanks
