I have already created another topic on this problem called Border Router OTA using WiFi, which was getting rather long and if I continue that thread, it might deviate from what I initially asked. So I wanted to raise a new topic to ask this question.
Since I do not have IPv6 on my WiFi network, I am currently attempting a workaround by making an ESP32 AP. I setup a Linux (Ethos) ā ESP32 (WiFi_AP) router using the same gnrc_border_router example, to which other ESP32 boards running the actual WiFi<->SLIP router from my original setup can be connected. I am not sure if this will work and Iād appreciate some suggestions.
I added a line in the Makefile.board.dep of the gnrc_border_router example to setup an Ethos<->WiFi router.
@@ +7,5
ifeq (,$(filter native,$(BOARD)))
ifeq (slip,$(UPLINK))
USEMODULE += slipdev_stdio
else ifeq (ethos,$(UPLINK))
USEMODULE += stdio_ethos
+USEMODULE += esp_wifi_ap
else ifeq (wifi,$(UPLINK))
ifneq (,$(filter esp32 esp8266,$(CPU)))
I can see the following ifconfig output on ESP32 (AP)
Iface 8 HWaddr: 24:6F:28:95:D1:19 Channel: 0 Link: up
L2-PDU:1500 MTU:1500 HL:64 RTR
RTR_ADV
Source address length: 6
Link type: wireless
inet6 addr: 2001:db8::266f:28ff:fe95:d119 scope: global VAL
inet6 group: ff02::2
inet6 group: ff02::1
inet6 group: ff02::1:ff95:d119
Iface 9 HWaddr: 66:91:6E:95:1E:58
Link type: wired
inet6 addr: fe80::6491:6eff:fe95:1e58 scope: link VAL
inet6 addr: fe80::2 scope: link VAL
inet6 group: ff02::1:ff95:1e58
inet6 group: ff02::1:ff00:2
Using the suggested Makefile changes from the topic Border Router OTA using WiFi, I connected another ESP32 to the AP, setup the ESP32-Nucleo connection and got the same outputs as before.
ESP32 (Router):
2023-10-19 14:32:21,072 # ifconfig
2023-10-19 14:32:21,077 # Iface 7 HWaddr: A4:CF:12:9A:2D:C8 Channel: 1 Link: up
2023-10-19 14:32:21,081 # L2-PDU:1500 MTU:1500 HL:64 RTR
2023-10-19 14:32:21,084 # Source address length: 6
2023-10-19 14:32:21,086 # Link type: wireless
2023-10-19 14:32:21,092 # inet6 addr: fe80::a6cf:12ff:fe9a:2dc8 scope: link VAL
2023-10-19 14:32:21,095 # inet6 group: ff02::2
2023-10-19 14:32:21,097 # inet6 group: ff02::1
2023-10-19 14:32:21,101 # inet6 group: ff02::1:ff9a:2dc8
2023-10-19 14:32:21,102 #
2023-10-19 14:32:21,103 # Iface 8
2023-10-19 14:32:21,107 # Long HWaddr: 66:11:DA:1D:BE:FC:7E:AF
2023-10-19 14:32:21,110 # MTU:65535 HL:64 RTR
2023-10-19 14:32:21,112 # RTR_ADV
2023-10-19 14:32:21,114 # Link type: wired
2023-10-19 14:32:21,120 # inet6 addr: fe80::6411:da1d:befc:7eaf scope: link VAL
2023-10-19 14:32:21,126 # inet6 addr: 2001:db8::6411:da1d:befc:7eaf scope: global VAL
2023-10-19 14:32:21,129 # inet6 group: ff02::2
2023-10-19 14:32:21,131 # inet6 group: ff02::1
2023-10-19 14:32:21,135 # inet6 group: ff02::1:fffc:7eaf
Nucleo (RIOT Node):
2023-10-19 14:23:00,959 # ifconfig
2023-10-19 14:23:00,963 # Iface 4 HWaddr: EA:C8:61:14:DB:02 Link: down
2023-10-19 14:23:00,967 # L2-PDU:1500 MTU:1500 HL:64 RTR
2023-10-19 14:23:00,970 # Source address length: 6
2023-10-19 14:23:00,973 # Link type: wired
2023-10-19 14:23:00,979 # inet6 addr: fe80::e8c8:61ff:fe14:db02 scope: link VAL
2023-10-19 14:23:00,982 # inet6 group: ff02::2
2023-10-19 14:23:00,984 # inet6 group: ff02::1
2023-10-19 14:23:00,988 # inet6 group: ff02::1:ff14:db02
2023-10-19 14:23:00,989 #
2023-10-19 14:23:00,990 # Iface 5
2023-10-19 14:23:00,994 # Long HWaddr: AE:97:D8:31:A6:13:BD:6E
2023-10-19 14:23:00,997 # MTU:65535 HL:64 RTR
2023-10-19 14:23:00,998 #
2023-10-19 14:23:01,001 # Link type: wired
2023-10-19 14:23:01,007 # inet6 addr: fe80::ac97:d831:a613:bd6e scope: link VAL
2023-10-19 14:23:01,013 # inet6 addr: 2001:db8::ac97:d831:a613:bd6e scope: global VAL
2023-10-19 14:23:01,016 # inet6 group: ff02::2
2023-10-19 14:23:01,018 # inet6 group: ff02::1
2023-10-19 14:23:01,022 # inet6 group: ff02::1:ff13:bd6e
2023-10-19 14:23:01,023 #
I am able to ping the ESP32 router which is connected to the PC (Ethos<->WiFi). I need to know how to setup a route so that I can ping the Nucleo node from the Linux PC. The end goal is actually to trigger a SUIT update on the node, but initially I want to know if this is going to work.
