finally, I'm trying to improve the doxygen documentation of
board*.h/periph*.h configuration files for my ESP8266 port.
I tried to use the @name command together with @{ and }@ , to group all
definitions that are related to a certain peripheral interface, e.g.,
I2C interface.
It seems that the resulting HTML code differs for such group definitions.
For example, in
http://riot-os.org/api/boards_2native_2include_2board_8h.html
the definition "LED handlers" and "MTD emulation configuration" are
documented in the same way with the @name command. However, the output
differs for them.
Is this a problem of doxygen or do I miss something?
Regards
Gunar
it seems that the style of the output changes either if a variable or
function declaration is part of such group.
But this is not always the case. For example, even though there are such
declarations in
"LED handlers" and "MTD emulation configuration" look different.
Regards
Gunar
Hi Gunar,
declarations in
I find it useful to enable XML output in Doxygen and inspect the resulting XML. This will indicate if its a structure problem (meaning you messed up) or a rendering problem (meaning Doxygen messed up).
In this case you are right, and the XML shows "LED Handlers" and "MTD emulation configuration" both correspond to `<sectiondef kind="user-defined">` elements, with no difference other than their contents.
I think that what happens is that Doxygen presentation logic automatically detects groups with preprocessor definitions only and nests them under a "Macros" section. Unfortunately, there's not much that can be done to customize this behavior (see https://www.stack.nl/~dimitri/doxygen/manual/customize.html)
Juan.
Hi Juan,
thanks for your answer.
In the meantime I could figure out that the enabled subgrouping causes
this problem if all group members are of the same type.
I have opened issue #9849 which describes the problem in detail and how
it could be solved. It's just a suggestion for better output quality.
Let's see what RIOT's maintainers think about it.
Regards
Gunar
