Dear everyone,
I've worked on the power management for the atmega platform at the RIOT Hackathon. While creating PRs for the different parts, I stopped at a critial point I would like to discuss here:
Several functions are used for the power management and stubs are provided in drivers/periph_common/pm.c. However as mentioned in one issue, the weak implementation did *not* work correctly. Therefore we agreed on removing weak definitions for the module and use some #ifdefs instead:
#if !defined( MODULE_PM_LAYERED ) void pm_set_lowest(void) { } #endif
Unfortunately, this does not work because some platforms and especially the stm32_common/kinetis_common/cortexm_common platforms define these functions all over the place!
My first question is there for, is there a good system to implementations for a module such as the PM module at different levels?
E.g. the CPU should always have the possibility to implement specific pm_* functions. A fallback could be provided in the common CPU. Additionally, the pm_layered module uses some of these CPU functions. And finally, the fallback functions in pm.c should be used, if none exist. Is it ok to use #define / #ifdef constructs for these? Any opinions? I think we need a very fine-granular system here. I started to add special features to handle this case:
makefiles/features.inc.mk
DEFAULT_FEATURES += periph_pm periph_pm_off periph_pm_set_lowest periph_pm_reboot
cpu/cortexm_common/Makefile.features FEATURES_PROVIDED += periph_pm_set_lowest
I thought that maybe features can be used to describe which functions are provided. Later on based on include/compile order, missing functions can be added if needed. Any opinions on this?
Best Regards, Robert
