DHT driver +RIOT
Hi everyone, I am trying to read temperature and humidity from DHT11 sensor. but it got an error :" Error reading values". I am debugging the “dht.c” code and find in " _wait_for_level" function there is problem. When the code try to (gpio_read(pin)), it can not do this. So, because of the finishing timer it return an error. I increased the timer but still it does not work. I attach my setup (arduino-uno+dht11)
as well as my code. I will be very appreciate if any one can help me
Blockquote
#define DELAY (10 * US_PER_SEC)
int main(void)
    /* Fix port parameter for digital sensor */
    dht_params_t my_params;
    my_params.pin = GPIO_PIN(PORT_D, 2);
    my_params.in_mode = DHT_PARAM_PULL;
    /* Initialize digital sensor */
    dht_t dev;
    int16_t temp, hum;
    if (dht_init(&dev, &my_params) == DHT_OK) {
        printf("DHT sensor connected\n");
    else {
        printf("Failed to connect to DHT sensor\n");
        return 1;
 while (1) {
        if (dht_read(&dev, &temp, &hum) != DHT_OK) {
            puts("Error reading values");
            continue;
        printf("DHT values - temp: %d.%d°C - relative humidity: %d.%d%%\n",
               temp/10, temp%10, hum/10, hum%10);
        xtimer_usleep(DELAY);
    return 0;
