In #16116 some thoughts where shared about RTT_FREQUENCY.
maybe a sensible default should be choosen.
there are two mainly used ~32kHz and 1Hz (non 1000Hz)
grep “define.*RTT_FREQUENCY” showed
32k 19
1 12
Max 3 (iotlab is one) at a first glace these are 32kibiHz
16k 3
1024 2
4096 1 (nucleo-f413zh)
there are 5 rtt users in sys/Makefile.dep
ztimer (likes to put msec on rtt)
posix_sleep ztimer_msec
gomach (somthing about 300ms supercycles)
lwmac (calculates in 2ms - 300ms range)
sklad ztimer_msec
since not every RTT is configurable a sane default should be choosen
i vote for ~32kHz
+1
The available frequencies could maybe be modeled as features. At least 32kHz, 1024kHz and 1hz. That way we can maybe make ztimer only depend on RTT if it provides a usable frequency.
11 of the 1 Hz ones are efm32*
i had a short read on a datasheet of that series and i support other perscalers
the current implementation is not able to be configured by setting RTT_FREQUENCY
maybe @basilfx is able to change that or get the default to something faster (i got no efm32 device and therefor can not test)
the other one is the arduino-due a sam3 which reads the RTT_FREQUENCY define for configuration
They should be configurable:
Yes it is available in the hardware library but for Riot it is set to a fixed value cmuClkDiv_32768
Most mcu take the RTT_FREQUENCY define and use it to configure the RTT.
atmega for comarison uses a function to calculate the prescaler,
stm32 (but f1) has a list of prescaler defines,
sam used a preprocessor function to calculate the value somehow)
I think this can be changed to work similar for efm32.
I don’t think i should write such an PR without being able to test.
The capability for configuration the way other mcu do that is added with https://github.com/RIOT-OS/RIOT/pull/16344
