Hi everyone,
I have a question about debugging with cc2538.
I 'm testing the 6LoWPAN function on both RIOT and Contiki-NG. While stepping debugging, RIOT works fine, but Contiki-NG fails.
I’m using the same debugging method for both: First, I connect JLink to the SmartRF06+cc2538EM. Then, I open JLinkDebugServer in one session and gdb in another.
When the gdb connection is established for Contiki-NG, it shows that the code step into 0xdeadbeee. and the JLinkDebugExe output
Reading common registers: ERROR: Cannot read register 0 (R0) while CPU is running
Read register 'r0' (4 bytes) from hardware: 0xEFBEADDE
ERROR: Cannot read register 1 (R1) while CPU is running
Have anyone encounter this problem or notice any information related when implementing the RIOT cc2538 part.
Any insights related to this problem or helpful information would be greatly appreciated.
I’ve asked about this on the Contiki-NG github issue but I haven’t received a response for several weeks.
Thanks, Dingisoul
