Can we compile a program with CompCert then integrate it with other RIOT-OS modules (compiled by GCC) and finally flash the result into a support board?
If so, how to do it?
For example, A helloWorld program
//bench_compcert/main.c
#include <stdio.h>
int main(void) {
printf("HelloWorld\n");
return 0;
Currently, when I do BOARD=nrf52840dk make -C tests/bench_compcert WERROR=0 flash, it uses default gcc to compile all used modules and my program. While I hope to
- use GCC to compile RIOT-OS modules
- use CompCert to compile my code
and then produce a .elf / .bin files…
A real-world case is that my program relies on some CompCert build-in functions, and I hope to run this program + RIOT-OS on my board.
