ccn-lite example " simple forward" fails
I am trying to play RIOT with ccn-lite example (ccn-lite-client and ccn-lite-relay) on ubuntu using native board.
I follow the instructions in the HOWTO document under ccn-lite-client folder. For the “simple appserver (all in one shell)” scenario, it succeeds.
But, for the simple forward (needs two shells) scenario , it failed. I’ve successfully setup the second shell which is populating /riot/text/… For the first shell, the result of command “interest /riot/text” is " riot_get returned 0 bytes…aborting! ". I exactly followed the instructions.
Can anyone give me any hint for this?
Thanks,
Xili
Can you communicate between two nodes directly, for example with /examples/default ?
Cheers,Ludwig
