Hey guys, has anyone succeeded in providing riotboot support for the cc2538dk board as yet?
Hi Brenton!
So far I remember we didn't take it into account, and I don't know if someone is taking care of it.
As far as I know, there are two ways of supporting that CPU:
1. The way we do it now, which is linking the image in another start address so the bootloader can recognise it and boot it.
2. Modify the start address on the CC2538 register dedicated to this. This might be a bit tricky but also interesting for the sake of research and compatibility.
However, I'd advice the first option to have the full benefits of the bootloader and struggling less with the particular settings on that chip.
Overall, the steps would be the following:
1. Adapt the linker scripts to succeed tests/cortexm_common_ldscript. This consists on making the linker scripts on cpu/cc2838/ldscripts comply with cpu/cortexm_common/ldscrpts/cortexm.ld. You might take a look how is it done for stm32 or sam0 families.
2. Provide the length and start variables to link slots correctly: Â Â Â - ROM_LEN Â Â Â - RAM_LEN Â Â Â - ROM_START_ADDR Â Â Â - RAM_START_ADDR
Again, take a look on the supported CPUs as examples.
3. Make tests/riotboot pass
4. Perform a firmware update or flash different firmwares with different versions so the bootloader choses the newest.
Optionally you might want to test if the WIP SUIT update format works.
Don't hesitate to make more questions if you have some!
Paco.
Hi Brenton,
if you only use the default `riotboot/flash` or `flash` in `tests/riotboot` targets, you do not need flasher changes. But you should not use `riotboot/flash-slot0` and `riotboot/flash-slot1` targets for the moment.
To have the support declared and merged in RIOT, it also needs to support flashing the `slot-` firmwares alone. These require having flasher that can flash with an offset`.
For `cc2538-bsl.py` it looks like there is the `-a` option for this.
Maybe changing it to use `IMAGE_OFFSET` if set would be enough. An example is in https://github.com/RIOT-OS/RIOT/blob/8fe12bc82cfbb83a90efd018e11c044d0a40696b/makefiles/tools/edbg.inc.mk#L14-L15
The `flash.sh` is currently using `jlink` without using the common `jlink` scripts thing, it is in my todo list after https://github.com/RIOT-OS/RIOT/pull/11554 to migrate to use the common one where applicable.
Cheers, Gaëtan
Seems to me that a quick riotboot porting guide could be useful somewhere in the wiki.
More in the `riotboot` documentation in the repository I would say.
FYI I opened a PR adding a WIP porting guide: https://github.com/RIOT-OS/RIOT/pull/11597
Thanks for the advice guys, but Iâm still struggling to get the cc2538dk to pass the riotboot tests.
I provided the length and start variables to link the slots. I used the cc2538sf53.ld Linker Script.
I was not sure how to get the offset required, so i used 255 as the offset, this value made the slot0.riot.bin file = 512KB.
I assume this correct because whenever you compile an example (not with riotboot), it generates a .bin file with this size.
Any ideas on what i could be doing wrong?
With thanks! Brenton
Hey guys, i kind of managed to get the riotboot tests to pass. Whenever i program via terminal (gcc-arm) i receive the error â[FAILED] Youâre not running riotbootâ. But when i program via the UniFlash tool, it works. Note, so far only âtests_riotboot-slot0-combined.binâ works. I assume its an offset issue as GaĂ«tan mentioned. Also, I used the cortexm_base.ld Linker Script.
Thanks for the help guys
Hi GaĂ«tan, i managed to get the tests/riotboot to pass whilst using âriotboot/flash-combined-slot0â. I also used the â-aâ option For âcc2538-bsl.pyâ. This allowed me to use the âriotboot/flash-slot0â successfully. However, i couldnât get slot 1 working. How do think i should approach this problem. And currently i can only use âriotboot/flash-slot0â whilst using the â-aâ option For âcc2538-bsl.pyâ. What is the RIOT approach to implementing this?
With regards Brenton
Hi Brenton,
I noticed there is `-e` in `FFLAGS` which performs a full erase of the rom so flashing a second slot while the first one or the bootloader is there cannot work.
We removed this full erase from all flashers for boards using `riotboot`. If the flasher erases only what is required for flashing it could be removed from the default configuration. And it was the case for `edbg/openocd/jlink`.
Regards, Gaëtan
So you can try without the `-e` in `FFLAGS` and see if first flashing `slot1` works and if it is also not destroying your normal workflow ?
Hi Gaëtan
I managed to get riotboot to select the newer image between slots 0 and 1. I had to first flash âriotboot.binâ (from $RIOTBASE/bootloaders), then slots 0 and 1 without doing a full erase.
How do i link the Makefile in (boards/cc2538dk/Makefile.include) to (sys/riotboot/Makefile.include) so that i can use âIMAGE_OFFSETâ for the â-aâ option in âcc2538-bsl.pyâ. It currently says âIMAGE_OFFSETâ was not declared (same with SLOT(0/1)_OFFSET). Also, why was it that i needed to flash âriotboot.binâ first. Shouldnât the bootloader automatically be flashed when using the âriotboot/flash-combined-slot0â command?
Note, the flashbase address for the cc2538 is 0x200000. I flashed âriotboot.binâ at 0x200000, then slot0 at 0x201000, then slot1 at 0x240700. For âriotboot.binâ, I compiled using SECTIONS { .flashcca : { KEEP(*(.flashcca)) } > cca } // so the filesize for âriotboot.binâ was 512KB, then slot images were around 15KB each. The CCA section consists of 44 bytes at the end of flash
Regards Brenton
Please ignore my previous email. I forgot to add â$()â for $(IMAGE_OFFSET). Everything seems fine now. Just need to find out how to erase the necessary flash instead of a complete erase.
Regards Brenton
Please ignore my previous email. I forgot to add '$()' for $(IMAGE_OFFSET). Everything seems fine now. Just need to find out how to erase the necessary flash instead of a complete erase.
The `-e` option is used by default, if it works without it at all, you should be good.
-e Erase (full)-
