@Baptiste: How did the CC1350 get into this round :-)? Is it similar to
the other mentioned radios? In any way, I would be pretty happy to see
support for that radio in RIOT. It would enhance the current SensorTag
support significantly.
@Anon: I have no idea about the differences between CC1101 and CC1200
(and CC1350). Whenever possible we try to avoid code duplication so if
you think it's easily 'possible' so extend the CC1101 driver, you should
go that way. If that means `#ifndef CC1200` in every second code line,
you should probably avoid it and write a standalone driver.
