I posted about this before but took it down as I was convinced I missed something.
I have been running RIOT with nanocoap + sensors and it consumes about 10mA and using pm_set() only drops the current by about 3mA.
I have been looking at the datasheet on how to set the transceiver to sleep to get even lower consumption.
Following the procedure I have used:
/*set sleep pin low*/
gpio_clear(AT86RF2XX_PARAM_SLEEP);
/* set pin state to TRX_OFF, FORCE_TRX_OFF,STATE_SLEEP also attempted */
at86rf2xx_set_state(&dev, AT86RF2XX_STATE_TRX_OFF);
/* set sleep pin high*/
gpio_set(AT86RF2XX_PARAM_SLEEP);
pm_set(0);
However, when the set_state() function is executed the code gets stuck and I’m unable to either set the pin or enter the low power mode. The rtt that is meant to interrupt the sleep but still keeps going and does do a callback.
I put some print statements in the at86rf2xx_set_state() function and it seems to be looping in there.
I have also tried putting my sleep procedures in the at86rf2xx test files and it still gives me the same result.
Any help would be appreciated on how to proceed.
Thank you.
