Hi everyone
I am trying to use microcoap example from RIOT repository in FIT-IoT
LAB. So I upload microcoap in an M3 node and I have a CoAP-client in my
linux pc. I want to make a remote connection ( coap-client from
my pc ask for a resource from coap-server in M3 node). I need a Border Router.
So I will use another m3 node for that purpose. Is there any border router for m3 node available?
Is there any other way to make this remote connection?
All the best
Theodore
Dear RIOT-Users
Someone can help with this.
All the best
Theodore
Quoting Theodore Kotsonis <kotsonis@aueb.gr>:
first of all sorry that nobody replied to your earlier mail. Did you have a look at ethos? It provides an Ethernet over the serial line and should also work on the IoT-Lab.
Hope this was helpful.
Martine
Dear Martine
Thank you for the reply. I have seen ethos but I don't know how to use it. I have seen the documentation
but I need some steps and a little bit explanation
All the best
Theodore
Quoting Martine Lenders <authmillenon@gmail.com>:
Hey Theodore,
do you want to use a border router?
If not,
- add the lines as recommended in "dist/tools/ethos/README.md" to your application's Makefile
- also add "CFLAGS += '-DSTDIO_BAUDRATE=115200'"
- remove "USEMODULE += gnrc_slip" (if any)
- compile & flash the node
- compile ethos by running "make" in "dist/tools/ethos"
- run ethos in "dist/tools/ethos": "ethos tap0 <your-iotlab-m3-serial-port>"
At this point, you should have serial output of the node showing up as output of the ethos command.
If you've tried with the microcoap_server example, there'll be no output after some initial status. Try calling "BOARD=iotlab-m3 make reset" in examples/microcoap_server, in another shell.
If you can see output, "only" thing left is configuring the network.
Dear Kaspar
Thank you again for the reply. I run the microcoap_example in native board and now I want to upload the experiment in a M3 node ( only the coap-server ) . CoAP client ( I take it from libcoap ) will be in my pc ( linux process ) and I send request from client to take a response from server ( coap-client "coap://[(IPv6 of Coap-server)%tap0]:(Port)/riot/board ). But because of FIT-IoT lab and IPv6, I found that I need a border router. If i can avoid border router and make this connection, its ok.
You propose me ethos. So I can add the lines as recomended in my CoAP application.
Something that I must figure out.
Which is <iotlab-m3-serial-port> ?
( Sorry if something is really obvious but I am new in all these )
All the best
Theodore
Quoting Kaspar Schleiser <kaspar@schleiser.de>:
Dear RIOT-users
I want to thank you again for the help.
Someone can explain about <iotlab-m3-serial-port> that Kaspar mention in previous post
All the best
Theodore
“Theodore Kotsonis” <kotsonis@aueb.gr> (on users@riot-os.org):
Dear RIOT-users
Someone can explain about that Kaspar mention in previous post
Has anybody experience with accessing the serial port of a serial port of a node on the IoT-LAB testbed?
