What is RIOT's position on using named bitfields for register
definitions ? I know they are frown upon as there are no endian
guarantees in the C standard, personally I don't use them, but the PIC32
device files supplied by Microchip do include bitfield structures for
most registers so could make life easier ? (thankfully there are #define
for most register fields too, if the answer is not to use them).
though named bitfields are kind of nice when it comes to code readability, they behave very poorly when it comes to code size. This is especially true for register maps, as these are typically volatile. For this reason, we don't use them in RIOT and I strongly advice not to use those.
As example I was able to save several 100 bytes of ROM when removing the named bitfield use from the samr21s peripheral drivers.
are you suggesting the compiler generated code for accessing the bitfeilds is less size efficient than doing it manually? I would be suprised if that was the case ?
Marinte's example does not use `volatile` fields, this makes it in my experience even worse...
Anyhow, it still shows, that on Cortex based platforms, the manual approach is superior in terms of ROM usage (which fits with my experiences). So especially for register maps (which are completely tied not only to a platform but to a specific CPU) I see a negative effect from using named bitfields.
@Neil: yes, I am suggesting (also backed by Martine's example) that compiler generated code for accessing the bitfeilds is less size efficient on Cortex-Mx based platforms. But please feel free to prove me wrong!
Ok so they are not outright banned but not recommended unless you can prove there are not any code size penalties?
I’m now very interested in testing this on MIPS and will be querying our compiler engineers if there is a difference. I wonder if the fact that volatile acts as a compiler memory barrier that the compiled code is larger?
writing to a bitfield translates to a read followed by a write of the
updated value. So if you write to multiple bitfields in a register you
have multiple read-write pairs. These can't be combined when the
bitfields are volatile. Similar for multiple reads of a register.
When you use shift and mask you usually do a single access for
all fields of a register.
IMHO it is also better to use shift and mask because a write to a
bitfield is actually a hidden non-atomic read-update-write, which
may become dangerous when you have concurrent access.
I would say yes. If the code size is the same, I would not mind using named bitfields.
I'm now very interested in testing this on MIPS and will be querying our compiler engineers if there is a difference. I wonder if the fact that volatile acts as a compiler memory barrier that the compiled code is larger?
Please share what you find out, I would be very interested in their view!
About the volatile: I think Jürgen put it very nicely in his description.
I have a hard time to believe that a modern compiler makes worse
code for bitfields. Volatile or otherwise.
When I convert sam21_common spi.c to use the bitfields, the code
becomes 4 bytes less.
Of course it is a different story if you want to modify several bits together.
Splitting it, just to use the bitfields can increase the code size.
-- Kees
