Dear all, Is it possible to create a bin file, which includes everything and then flash the .bin file on the board? (From what I’ve seen RIOT OS doesn’t support this, right???)
Thank you in advance!
Best, Ilias
Best, Ilias
Hi Ilias!
I guess you need glasses
If you have your target exported, then 'make' creates a binary image. 'make flash' flashes this image onto your board.
Cheers, Ludwig
If you want a binary file which is an exact byte-for-byte copy of the microcontroller ROM you can use objcopy to convert from ELF to raw binary. The RIOT build system also produces a HEX file for flashing, which is a plain-text variant of the raw binary.
arm-none-eabi-objcopy -O binary myprog.elf myprog.bin
You will not, however, need any of this manual handling for flashing the supported boards, make flash
is all you need.
Best regards, Joakim
Thank you all for your replies!
@Ludwig I do wear glasses
The problem is that I have a board based on samr21 but there is no edbg usb port, on the datasheet it mentions only reprogramming using a usb pen drive and a .bin file, I know nothing about the bootloader.
Hi Ilias!
Hi again, I was given an Atmel Ice device, has anyone used it? Thank you in advance!
Your Faithfully, Ilias Seitanidis
The blue one? It’s basically the same hardware as a SEGGER JLink but the firmware locks it to Atmel only devices. You can use JLinkExe to interact with it.
Yes, I have one, and I use it to burn and to debug. I'm using openocd.
What do you want to know?
Thank you very much for your reply! I’m starting from scratch on using an external debugger. Everything is valuable
To burn a program you only need the ELF file. No need to convert it to BIN. Notice that I'm using a SODAQ Autonomo, with an Atmel SAMD21J18A. The openocd command is:
$ MYELF=tests/driver_bme280/bin/sodaq-autonomo/driver_bme280.elf $ openocd -d2 -f boards/sodaq-autonomo/dist/openocd.cfg -c "telnet_port disabled; init; halt; at91samd bootloader 0; program {{$MYELF}} verify reset; shutdown"
To be able to debug you must start openocd as a daemon waiting
for GDB to connect. (You are using GNU I hope.
$ openocd -d2 -f boards/sodaq-autonomo/dist/openocd.cfg -c "init; halt; at91samd bootloader 0"
Then start gdb with the ELF file.
$ arm-none-eabi-gdb -i=mi tests/driver_bmp180/bin/sodaq-autonomo/driver_bmp180.elf
In gdb you first connect to the target, give it a reset, set breakpoints and give it a go.
(gdb) target remote localhost:3333 (gdb) monitor reset halt (gdb) b main (gdb) c
And of course, YMMV
