I’ve moved a 6LowPAN gnrc_networking project on the SAMR30-xpro from 2022.04 to 2023.1. In my previous build everything came up correctly and the radio would connect to the border router.
With 2023.01 it does not.
Looking at ifconfig I see the default channel page is being ignored and set to 0 for some reason. For the RF212B it should be 2 which is set here:
sys/include/net/ieee802154.h:256:#define CONFIG_IEEE802154_DEFAULT_SUBGHZ_PAGE (2U)
and then here:
drivers/include/at86rf2xx.h:#define AT86RF2XX_DEFAULT_PAGE
I see this as well with the gnrc_networking example as well. I have not been able to track down why its being ignored.
Has anyone else seen this?
Thanks, Matt.
I Still don’t know why the default page is being ignored but but I have worked around it programmatically:
uint16_t channel_page = 2;
netif_set_opt((netif_t*)&netif->netif, NETOPT_CHANNEL_PAGE, 0, &channel_page, sizeof(uint16_t));
hi @mattwood2000
I think I found the problem.
After restructuring the driver, it turns out the variable dev->page is never being set. Since the device descriptor is allocated in the data segment, it is always zero.
This is definitely a bug (which we should fix for the upcoming release), but you can try this as a quick fix:
diff --git a/drivers/at86rf2xx/at86rf2xx.c b/drivers/at86rf2xx/at86rf2xx.c
index 77e6daab93..ee5626abce 100644
--- a/drivers/at86rf2xx/at86rf2xx.c
+++ b/drivers/at86rf2xx/at86rf2xx.c
@@ -85,6 +85,11 @@ void at86rf2xx_reset(at86rf2xx_t *dev)
/* set default channel, page and TX power */
at86rf2xx_configure_phy(dev, AT86RF2XX_DEFAULT_CHANNEL, AT86RF2XX_DEFAULT_PAGE, AT86RF2XX_DEFAULT_TXPOWER);
+ /* Record the default channel page in the device descriptor */
+#if AT86RF2XX_HAVE_SUBGHZ
+ dev->page = AT86RF2XX_DEFAULT_PAGE;
+#endif
/* set default options */
if (!IS_ACTIVE(AT86RF2XX_BASIC_MODE)) {
Please let me know if it works.
Hi again,
I tested that patch on IoT-LAB and it seems to solve the issue.
