I wanted to ask if the latest Arduino Uno Rev 4 is supported by RIOT, I have looked through the supported boards and it seems like it’s not there, however if we look at the specs of this board (it runs an Arm Cortex M4 and has an esp32-based wifi module) I thought that using a board configuration for the same MCU could work fine.
Has anyone tried running RIOT on that particular microcontroller? Or is there some board name that I should use which is equivalent to the new Rev 4?
Currently RIOT does not support Arduino R4 board yet. I think it won’t be too hard to run RIOT on the esp32 side. However, it will be a little bit more hard on the Cortex M4 side as we don’t support any Renesas microcontroller yet.
I encourage you to create an issue on github that could be used to gather people interested in adding support to this board.
