I probably am not the only one that likes to save a few minutes of reading documentation by spending hours of trial and error or quickly implementing an already implemented feature…
Since we use make as our own CLI, I wonder if we should put a little more effort into including documentation in make.
We do have make help that simply lists some targets. Within these targets we have info-* but I somehow think we can do better. The immediate thing would be to have at least a description of each of targets and maybe also a way to show a subset of env variables, the usage and description.
Something like:
> make help
all - builds the application
info-boards - prints all boards
info-boards-supported - prints all boards supported for this application
info-env-vars - describes common env variables used in RIOT for option setting
test - runs automated test for the application if it exists
> make info-env-vars
BUILD_IN_DOCKER
Description: Builds the the riotbuild docker container instead of host system
Usage: BUILD_IN_DOCKER=1
BOARD
Description: Selects the board to execute commands on, check info-boards-supported for information on which boards can be used
Usage: BOARD=native, BOARD=nucleo-f103rb
PORT
PROG_DEV
PROGRAMMER
for example.
I guess I would like to know if it makes sense or if it is just me that likes having documentation at hand. Maybe also some if there are some clever ways of adding an maintaining it rather than just printing the information. I somehow want one information source so we don’t have docs and the make info out of sync. Eventually we can think about how to enforce people provide documentation when adding targets…
Suggestions?
