Hi Kaspar,
Thanks for the tip, but while i was waiting for the reply i did it
Include the “shell_commands.h” and try something like :
char** argum[] = {“fibroute”, “add”, “::”, “via”, “fe80::1ac0:ffee:1ac0:ffee”};
_fib_route_handler(5, argum);
This above is just an example with a fixed root ipv6 address.
I would suggest to use the functions directly instead of “sailing” around them with shell commands.
You will need the following:
// the :: destination address [1]. (Alternatively it can be set anywhere using [2] or [3])
ipv6_addr_t dest = IPV6_ADDR_UNSPECIFIED;
// your next-hop
ipv6_addr_t next = IPV6_ADDR_UNSPECIFIED;
// for example you can use [3] to get the ipv6 address from a string (or set the values manually)
ipv6_addr_from_str(&next, “fe80::1ac0:ffee:1ac0:ffee”);
// get your interface pid of your transceiver handling the address [4]
kernel_pid_t iface = gnrc_ipv6_netif_find_by_addr(NULL, next);
// prepare FIB flags with prefix length of your destination, i.e. 128 for ::
uint32_t dst_flags = ((uint32_t)128 << FIB_FLAG_NET_PREFIX_SHIFT);
// and finally add the entry to the FIB [5]
fib_add_entry(
&gnrc_ipv6_fib_table, // the FIB table is accessible when GNRC+FIB is used [6]
iface,
dest.u8, sizeof(ipv6_addr_t), dst_flags,
next.u8, sizeof(ipv6_addr_t), 0,
FIB_LIFETIME_NO_EXPIRE // prevents auto-removing of this entry by the FIB
I haven’t tested the code-snips, but in general this should work.
I hope it helps a bit.
Best Regards,
Martin
[1] https://github.com/RIOT-OS/RIOT/blob/master/sys/include/net/ipv6/addr.h#L88
[2] https://github.com/RIOT-OS/RIOT/blob/master/sys/include/net/ipv6/addr.h#L559
[3] https://github.com/RIOT-OS/RIOT/blob/master/sys/include/net/ipv6/addr.h#L730
[4] https://github.com/RIOT-OS/RIOT/blob/master/sys/include/net/gnrc/ipv6/netif.h#L466
[5] https://github.com/RIOT-OS/RIOT/blob/master/sys/include/net/fib.h#L135
[6] https://github.com/RIOT-OS/RIOT/blob/master/sys/include/net/gnrc/ipv6.h#L99
