6lowpan issue again
I am picking up a project I worked on last year with setting up a 6lowpan border router on a Linux box to talk to RIOT nodes.
I had this stuff working last year but now I’m stuck where I cannot ping or communicate with global scope addresses. For reference this is my post from last year:
On my Linux box I have radvd configured just as I did previously. The RIOT nodes (2022.04) are compiled with -DCONFIG_GNRC_IPV6_NIB_SLAAC=1. I see a global scope address marked as valid.
I can ping the LL address from each side just fine. On the Linux box I can ping the multicast group and get a response from the RIOT node: ping6 ff02::1%lowpan0 64 bytes from fe80::24db:56ee:8137:dc92: seq=0 ttl=64 time=1.050 ms 64 bytes from fe80::ec0a:363b:7506:d64d: seq=0 ttl=255 time=12.710 ms (DUP!) 64 bytes from fe80::24db:56ee:8137:dc92: seq=1 ttl=64 time=0.684 ms 64 bytes from fe80::ec0a:363b:7506:d64d: seq=1 ttl=255 time=11.751 ms (DUP!)
But, pinging the node directly doesn’t work: ping6 fde1:cb6f:732a:8706:ec0a:363b:7506:d64d PING fde1:cb6f:732a:8706:ec0a:363b:7506:d64d (fde1:cb6f:732a:8706:ec0a:363b:7506:d64d): 56 data bytes ping6: sendto: Network is unreachable
ip -6 neigh show fe80::24db:56ee:8137:dc92 dev lowpan0 lladdr 26:db:56:ee:81:37:dc:92 router STALE fe80::ec0a:363b:7506:d64d dev eth0 FAILED fe80::ec0a:363b:7506:d64d dev lowpan0 lladdr ee:0a:36:3b:75:06:d6:4d router REACHABLE fe80::bb52:a311:e9eb:d68f dev eth0 lladdr 54:e1:ad:20:26:65 STALE fde1:cb6f:732a:8706:ec0a:363b:7506:d64d dev lowpan0 lladdr ee:0a:36:3b:75:06:d6:4d router STALE
I also note that my global scope group is not shown in the output of route -A inet6. It only shows the LL scope prefix fe80::/64.
Any idea what is going on here and why this worked last year but not now? I am on a slightly different kernel, and I’m sure radvd has been upreved.
Matt via RIOT notifications@riot-os.org wrote: > (fde1:cb6f:732a:8706:ec0a:363b:7506:d64d): 56 data bytes ping6: sendto: > Network is unreachable
Can you do “ip -6 route show” as well? It looks like either your device has hanged IPs, or the lowpan0 bridge driver just isn’t working.
Maybe your desktop lost it’s IPv6, or your IPv6 is broken, but you should still be able to ping6 your fde1: ULA.
> now?  I am on a slightly different kernel, and I'm sure radvd has been
> upreved.
What do you mean by hanged IP?
ip -6 route show
::1 dev lo proto kernel metric 256 pref medium
fde1:cb6f:732a:8706::1 dev lowpan0 proto kernel metric 256 pref medium
fe80::/64 dev eth0 proto kernel metric 256 pref medium
fe80::/64 dev lowpan0 proto kernel metric 256 pref medium
I also incorrectly linked my post from last year, this is the correct post:
https://forum.riot-os.org/t/6lowpan-and-linux-radvd-issue/3636
Thanks, Matt.
Matt via RIOT notifications@riot-os.org wrote: >> Can you do “ip -6 route show” as well? It looks like either your >> device has hanged IPs, or the lowpan0 bridge driver just isn’t >> working.
Sorry. “Changed”
This is odd, as you should have a /64 route. Maybe you configured it with /128? That would explain your problems.
You hit the nail on the head, thanks so much! For some reason it was configured with a 128 prefix. Changing my static IP to /64 got it going!
Many thanks!
