I’m facing an issue with xtimer_usleep function. All is working fine for a while but ramdomly, this function never returns, and my task stays blocked. Actually, this is because the callback that is supposed to unlock the mutex is never called. I have investigated and i saw that in xcore_timer.c:464, the second argument of the while is always false. I don’t think this is the same issue as #7347. I tried to modified XTIMER_BACKOFF but without any success. Here is my clock configuration :
`#define CLOCK_HSI (16000000U) /* internal oscillator / #define CLOCK_CORECLOCK (16000000U) / desired core clock frequency */
/* configuration of PLL prescaler and multiply values */ /* CORECLOCK := HSI / CLOCK_PLL_DIV * CLOCK_PLL_MUL / #define CLOCK_PLL_DIV RCC_CFGR_PLLDIV4 #define CLOCK_PLL_MUL RCC_CFGR_PLLMUL4 _/ configuration of peripheral bus clock prescalers /_ #define CLOCK_AHB_DIV RCC_CFGR_HPRE_DIV8 / AHB clock -> 2MHz / #define CLOCK_APB2_DIV RCC_CFGR_PPRE2_DIV1 / APB2 clock -> 2MHz / #define CLOCK_APB1_DIV RCC_CFGR_PPRE1_DIV1 / APB1 clock -> 2MHz / _/ configuration of flash access cycles */_ #define CLOCK_FLASH_LATENCY FLASH_ACR_LATENCY
/* bus clocks for simplified peripheral initialization, UPDATE MANUALLY! */ #define CLOCK_AHB (CLOCK_CORECLOCK / 8) #define CLOCK_APB2 (CLOCK_CORECLOCK / 8) #define CLOCK_APB1 (CLOCK_CORECLOCK / 8)
#define ENABLE_LSI (1)
/** * @name Timer configuration * @{ */ static const timer_conf_t timer_config[] = { { .dev = TIM2, .max = 0x0000ffff, .rcc_mask = RCC_APB1ENR_TIM2EN, .bus = APB1, .irqn = TIM2_IRQn } };
#define TIMER_0_ISR isr_tim2 #define TIMER_NUMOF (sizeof(timer_config) / sizeof(timer_config[0]))`
I have reduced all clocks to save power. I’m working on a stm32l073.
If you have any ideas about this issue, feel free to share your thoughts
Thank you in advance,
Aurélien
