Weekly coordination meeting
Hello everybody!
2026-03-13T14:00:00Z we will have our next weekly coordination meeting.
The meeting will take place online on Jitsi.
Please add your agenda items to our pad for the meeting minutes, so we know beforehand if there is anything to discuss (some people decide their attendance on that).
Best
Martine
Hello everybody!
2026-03-27T14:00:00Z we will have our next weekly coordination meeting.
Most of the people from TU Dresden and HAW Hamburg will be not be able to join, but please, feel free to organize among you.
Best
Martine
Hello everybody!
2026-04-10T13:00:00Z we will have our next weekly coordination meeting.
Best Mikolai
RIOT weekly coordination 10.04.2026, at 15:00 CET
Link: Jitsi Meet
Attendees
  • crasbe
  • carl
  • mikolai
  • karl
Note-takers
  • Moderation: Mikolai
  • Notes: Mikolai
meeting
Agenda
  • MCR asks: recent addition discussion about new maintainer (EF)… did something go wrong here?
  • CS asks: static const in headers
  • CS asks: SPI API
Notes
  • Carl: seems like black magic, just used to be optimized out
  • Karl: just works because never actually put in binary
  • Carl: is this a coding convention? are we sure optimizing out always works
  • crasbe: can we just try if linker is smart enough
  • Karl: compiler works per definition, linker might depend on implementation
  • mikolai: first step: document why we are using static const in headers
SPI API
  • Carl: API broken: meaning of SPI_DEV(x) not defined in documentation, physical peripherals not always defined as available, why are pins combined with peripherals
  • Karl: same with UART and I2C
  • carl: why?
  • karl: portability to other boards, I2C “just works”
  • crasbe: peripheral instances might differ quite a lot, different configuration etc, pins as defined on board
  • carl: concrete board: adafruit-feather-nrf52840-sense, why second SPI?
  • crasbe: second for flash. speciality for nrf52: you can freely configure pins for peripherals
  • Karl: most boards / MCUs have hard-wired peripherals anyways
  • carl: so again, missing documentation
  • carl: but still, not very beginner-friendly to need to change random headers
  • (some discussion about more user-friendly macro interface, but concerns about compiler optimizations)
  • crasbe: created a PR to improve documentation: drivers/periph/spi: add doc about multiple SPI buses by crasbe ¡ Pull Request #22185 ¡ RIOT-OS/RIOT ¡ GitHub
RIOT weekly coordination 24.04.2026, at 15:00 CET
Link: Jitsi Meet
Attendees
  • Karl
  • Marian
Note-takers
  • Moderation: Karl
  • Notes: Marian
Agenda
  • CI / Build System
Notes
CI / Build System
  • Marian: number of workers was quite depleted, dropping mobi6 resulted in PRs no longer mergable
  • Marian: Leandro added new workers, now CI time is acceptable again
  • Marian: might be worth to consider other strategies than throwing more hardware on the problem, specifically improvments in the build system to reduce the number of compilation taks
  • Marian: Currently 164,323 builds each compiles core/init.c, but only a few hand ful of different objects are expected
  • Marian: ccache can improve things, but needs to have 164,323 mostly identical copies of core/init.o due to -DRIOT_BOARD=... -DRIOT_APPLICATION=..., etc.
  • Marian: even if our compilation jobs would be fully cachable, a build system supporting dependencies and multiple outputs could reduce the compilation to just the actually different init.o objects, and link the same object into different outputs. That would be faster than ccache
  • Marian: Josh did sketch how th is could be done with some invasive changes in our build system, but sticking with GNU Make as build system and limited to no user facing changes
  • Marian: We might also look for other solutions. Looking into our build system makes it pretty apparent, that expertise on how to write good Makefiles is pretty scarce within our community. Probably Josh is the only one of us actually knowing how to write proper Makefiles.
  • Karl: Effort of changing the build system would be relatively large, optimizing ccache cachability would be a much faster way to reduce the pressure
  • Karl: We could provide board and app name as extern const char * instead, reducing the impact of them on the cachability
  • Marian: We could also still add flags for preprocessor stuff that is only available with #include "buildinfo/board.h" or #include "buildinfo/app.h". But still, even 99% identical boards such wemos-zero and arduino-zero differ in their module set. We would also need #include "buildinfo/modules.h" for that to have any impact.
  • Karl: That seems like a lot less effort than changing the build system
  • Marian: Miri NACKed on #include "buildinfo/modules.h" hard
RIOT weekly coordination 08.05.2026, at 15:00 CET
Link: Jitsi Meet
Attendees
  • mikolai
  • Karl
  • Martine
  • crasbe
Note-takers
  • Notes: Mikolai
Agenda
  • external api doc images
  • Developer QoL improvements
Notes
  • Karl: we might want to localize and replace them
    • they might go away (some are)
    • might expose api doc reader to tracing by image server (“cookie” banner need?)
    • github user contend is another github dependaciy
  • Martine: cannot just copy them depending on licence
  • crasbe: started making pictures of hardware lying around
  • Karl: as maribu did, but then they are lying on Github content servers
  • Martine: could convert them to jpg and check in in RIOT
  • Karl: might slow it down
  • crasbe: extra repo for static images on codeberg
  • Karl: doxygen doesn’t allow copying http images to static website
  • crasbe: could hack it into RIOT pkg
  • Martine: or classic git submodule, doxygen can have additional subpath configured
  • Karl: I might look into it
  • crasbe: additionally, board pages on guides site are broken (but probably starlight-problem)
  • crasbe: check-label should spam less mails
  • crasbe: static-tests merged in master before execution
  • crasbe: 4 PRs in riotdocker with QoL improvements
  • crasbe: will take over tinybuild migration
  • Mikolai: nice! what about image pinning?
  • crasbe: not yet existent
AOB
What does that mean :face_with_raised_eyebrow: @miri64
Oh wait I just realized what that means, hahahahah good point I totally forgot about that
Hello everybody!
2026-05-15T13:00:00Z we will have our next weekly coordination meeting.
Best
Martine
RIOT weekly coordination 15.05.2026, at 15:00 CET
Link: Jitsi Meet
Attendees
  • Martine
  • Maribu
  • Crasbe
Note-takers
  • Moderation: Martine
  • Notes: Martine
Agenda
  • Move Bluesky-Account to Eurosky?
Notes
  • Let’s try it. There is no real argument against it.
AOB
Hello everybody!
2026-05-22T13:00:00Z we will have our next weekly coordination meeting.
Best
Martine
Hello everybody!
2026-05-29T13:00:00Z we will have our next weekly coordination meeting.
Best
Martine
Hello everybody!
2026-06-12T13:00:00Z we will have our next weekly coordination meeting.
Best
Martine
RIOT weekly coordination 24.07.2026, at 15:00 CET
Link: Jitsi Meet
Attendees
  • crasbe
  • Ann
  • Teufelchen
  • mikolai
  • Karl
  • lukasseb
  • maribu
Note-takers
  • Moderation:
  • Notes: Mikolai (thank you Mikolai :heart:)
Agenda
Notes
Moving Forward with LTO by Default in RIOT
  • Teufelchen: related: stack protection by default, PR from 2020, should we just go forward with this? any volunteers to bring the default module selection mechanism up-to-date?
  • people generally agree
  • mikolai: requesting help for LTO bugfixing before next release in case something is broken
  • Teufelchen: commits on doing that
Vibe Coded Unicoap PR
  • crasbe: 4 lines, a lot of LLM-generated documentation
  • Ann: I was in contact with carl back then, I think I remember he was not amused by the bad quality of the LLM-contribution
  • crasbe: I want to see it closed >:)
  • Ann: I’ll double-check and will close it
  • maribu: Don’t waste human time on llm slop
Security Report Apocalypse: How to handle the load?
  • Teufelchen: load has increased. LLMs have become better, so often valid bugs, but badly documented/explained, and way to high CVE score
  • Teufelchen: maribu suggested to drop the security mailing list and the github security advisories and just use regular issues to streamline the process
  • Teufelchen: started tagging other maintainers when unsure / no expert
  • Teufelchen: would propose to “extend” special security group, send security reports to all maintainers
  • mikolai: but if everyone is responsible, noone feels anymore. prefer your old process of pinging people
  • Teufelchen: counter-argument: pinging didn’t work in the past @mikolai
  • mikolai: rather ping me outside / out-of-band
  • Ann: Maybe we should just stop doing it and move to suggested fix / PR, LLM makes finding these trivial and PR backlog is getting infinite
  • Teufelchen: current security group: Kasper, chrysn, maribu, Ann, Teufelchen, miri
  • Teufelchen: reducing security theatre would make things simpler (not assigning CVE, downgrading CVE levels)
  • mikolai, Ann: +1
  • Teufelchen: also more public disclosure? no “sneaking in” fix commits, no backlog of disclosure
  • maribu: default to CVE calculator?
  • Teufelchen: will do as discussed, let’s revisit in some weeks / on Summit for future strategy
Build System and CI Improvements
  • crasbe: speeding up make info-boards-* targets, which can greatly profit CI time in !22355 - those targets are extremely slow (24s can be reduced to 5s)
  • mikolai: what do you need?
  • crasbe: one open remark, then ACK
  • Teufelchen: a lot of overhead still spawning shells?
  • maribu: is trying to improve ccache efficiency by reducing configuration exposure to the compiler (e.g. board name, app name, etc) in stale !21954. Plans to reboot this together with !22467
  • maribu: cache key depends on cflags, which change for every single board/application
  • maribu: two simple improvements: board/application in header instead of as CFLAGS, only cfiles importing that header will need to be rebuilt
  • maribu: second: USEMODULE list appears to be somewhat random in the module order, putting those in header may break since IS_USED does just return false if undefined (not imported in c-file). proposal: always define module to true or false, error out when not defined (so include header)
  • maribu: ccache at home will not work anyways because bin dir is different for absolute paths, but it is constant in Murdock, so should work there
  • crasbe: IS_USED migration sounds like a good task for remaining LLM tokens
  • maribu: there is already a PR, will rebase, hopefully this weekend, will trim it down to minimal invasive changes
  • karl: just provide IS_USED within module header, will break at compile time
  • Teufelchen: should we aim for including more defines in those new headers
  • karl: no, keep them separate, otherwise we end up with a single riotbuild.h that we need everywhere?
AOB
  • maribu: Someone™ should become an Admin from the HAW/TUD group, bus factor too low
Hello everybody!
2026-07-31T13:00:00Z we will have our next weekly coordination meeting.
Best Chris
RIOT weekly coordination 31.07.2026, at 15:00 CET
Link: Jitsi Meet
Attendees
  • Ann
  • Lasse
  • crasbe
  • Teufelchen
  • Mikolai
  • karl
  • carl
  • maribu
  • Martine
Note-takers
  • Moderation: Ann
  • Notes: Mikolai (GOATED :handshake:)
Agenda
  • Where is Gunar Schorcht?
  • We need more admins :sad_but_relieved_face:
  • What’s the stance on LLM reviews?
  • Pulling the Plug of the Codeberg migration
  • Future of CoAP stacks in RIOT
Notes
  • crasbe: A lot of ESP32 related PRs were happening in the last couple of months and Gunar is the expert in that regard. I haven’t read or heard from him in a while. Should we try to reach out?
  • Martine: he’s a professor and might be busy with exams
  • maribu: has been like that periodically before
  • crasbe: no activity at all on Github, no responses to pings
  • Ann: was same before, e.g. in 2024
  • Martine: maybe try on Matrix? but maybe wait until September?
  • karl: do we need him or are we just concerned?
  • crasbe: no pressing issues right now
We need more (Github) admins :sad_but_relieved_face:
  • Ann: but Martine may be back soon?
  • Ann: who else is active and has admin rights?
  • Martine: community decision, bigger bus factor always better
  • Ann: proposing crasbe
  • crasbe: gut feeling: rather not, would prefer not having too much (public) presence and liability
  • Martine: proposing Mikolai
  • Martine: iirc, every stakeholder should have at least one admin according to governance.md
  • Martine: currently 7 admins in Sign in to GitHub ¡ GitHub hauke, martine, Cenk, Leandro, Peter, Kevin, benpicco, also see RIOT - The friendly Operating System for the Internet of Things
  • mikolai: maybe everyone thinks about it until summit, how many admins would be good, and who would be ready for it. then we discuss it there
  • Ann: summarizing: noone objects
LLM Reviews
  • Ann: Why did they suddenly pop up everywhere, did I miss something?
  • maribu: IMO better to use it publically instead of on private machine
  • Ann: just a bit surprised that we suddenly started having those
  • maribu: maybe because a convenient button was recently added
  • crasbe: but you may need a Copilot subscription
  • crasbe: do we want “AI:reviewed” then?
  • Ann: actually a lot of labels already
Review LLM topic happend here
  • maribu: any summary for this? do we want to allow AI-codereview for others, not just for ourselves?
  • Ann: maybe just on vibe-coded contributions?
  • maribu: 50c-1€ per review. would be cheaper with AGENTS.md
  • Ann: read that agents start to do the opposite of what they are asked to do in AGENTS.md
Review LLM
  • carl: general question: how to handle AI slop descriptions for AI contributions, example of recent unicoap PR
  • maribu: Agents.md with “please reduce the description to 150 words”
  • Ann: maybe not too bad to have Agents.md in general but makes project feel like AI slop even when agents.md anti-llm constraints
  • Teufelchen: disagrees (with having one)
  • Karl: just close AI:vibed?
  • Teufelchen: AI policy already disallows LLM-generated PR descriptions
  • Ann: so just close when “extractive PRs” according to AI policy, just not worth spending time on them
  • maribu: Codeberg recently updated their terms of use to ban projects that mostly consist of LLM generated code
  • maribu: The reasoning is given in an blog article and is mostly about heavy LLM users externalizing the cost to everyone else - a problem we see in RIOT as well
  • maribu: The blog article has some informal guidelines that are vague and difficult to apply. It also hints that further restrictions are still in dicussion.
  • maribu: The problem I have with that is that the codeberg is using the terms of use to get engaged into the technical decision making process of projects it hosts. That is IMO a transgression that is completely unacceptable. A git forge needs to stay technically neutral and leave the technical decision making to the projects.
  • maribu: IMO by injecting themselves into the technical decision making, Codeberg is no longer an acceptable forge for an independent project that strives to stay at the steering wheel of technical decision making
  • carl: agree. also added ban on cryptocurrency
  • Martine: feedback from codeberg community?
  • Mikolai: They decided it based on a democratic vote of the active members of the Codeberg e.V.
  • maribu: somewhat controversial internally, vote was fairly split, but the vote on what is acceptable Terms of Use retroactively is a bit dangerous
  • Mikolai: Disagrees with the fact that it should have been something from the start and not retroactively, LLM became a thing after foundation, they also argued that you can easily transfer your repository somewhere else, thus the question is whether or not we want to migrate and whether we are fine with the current ToS of codeberg, we all agree that github is not where we want to stay
  • Mikolai: the question is whether Codeberg is the right place to go for now, not in the future
  • Mikolai/Martine: We can’t make decisions based on potential future changes, we have to decide on what the current situation is
  • Karl: technical point that harms codeberg: LLM-scraping, LLM-agent resource use (extra dowloads, extra CI time)
  • Martine: but thats the scanning side, not the fact that projects are vibe-coded
  • Mikolai: In blog post they also talked about projects that used giant CI time but no one actually uses the project, causing issues for everyone
  • maribu: but CI quotas are easy to enforce
  • Martine: but maybe difficult to distinguish between LLM and humans
  • maribu: but same problem with their new policy
  • Martine, summarizing: consensus seems to be that we view this retroactive technical change of their ToS as a dangerous precedent, so we should reconsider our plans to migrate there
Preparatory notes
Discussion
  • maribu: agree with dropping gcoap: little maintenance, similar codebase. do not agree with nanocoap: trade-off is different: smaller stacksize
  • carl: overhead in unicoap is event-loop,…
  • carl: use-case for smaller stack?
  • Karl: bootloader, little applications
  • carl: but unicoap is much smaller than grnc in the stack below, especially for ip-based protocols
  • Martine: libraries should be smaller than application, especially relevant for bootloader
  • carl: agree with the argument, but not with the conclusion. reasons: 1) from user-perspective confusing to have to stacks, 2) (not mentioned since interrupted)
  • Martine: we also have two network stacks with gnrc and lwip
  • Martine: for non-ip-based protocols unicoap is smaller, as recently seen with slipmux
  • maribu: we have coap-over-can downstream, nanocoap is very small
  • carl: asking for numbers (KiB). overhead of unicoap is separate thread (async) + layering. could be further reduced with more configurations / optional modules etc
  • Karl: we can strive for one stack in the longer term, but not remove nanocoap right away. If it gets similarily small and we have numbers, we can discuss it then
  • Teufelchen: why do we have this discussion right now? unicoap is not ready yet to replace nanocoap. gcoap has no stakeholders present. but we can also just have several coap stacks next to each other
  • Martine: regarding downstream coap-over-can, unicoap might make it easier to integrate OSCORE for future-proofing
  • carl: finishing unicoap is further down the road, we talk about migration in 2 years from now, we could then have compatibility layer for nanocoap parser
  • Ann: agrees. cool about unicoap for beginners: a lot of documentation
  • Mikolai: reason for discussion in face-to-face meeting was the recent discussion on Matrix, which is always harder to have IMO. I disagree that we should have a large number of different CoAP implementations, maintainer time is limited.
  • carl: there’s a lot happening in the CoAP world, a lot of RFCs, we are far from feature-complete in all of our coap stacks. so agree that we should reasonably focus on not too many parallel stacks.
  • maribu: argument is unverschämt. you added a new CoAP stack while we already had 2 available ones.
  • carl: there was a tracking issue. you made your points there, but nanocoap was not a good ground to build on. people were complaining about out-of-buffer reads in nanocoap parser. messaging api of nanocoap_sock was not flexible enough. we didn’t start from scratch just because it was fun. adding all those features to nanocoap would have resulted in a lot of changes. I actually started from nanocoap source code and arrived eventually at unicoap.
  • Ann: understand maribu, but unicoap development was very public. discussion would maybe have had more sense two years ago, but here we are and I see that unicoap makes sense to have
  • Karl: we have migrated subsystems before, so we could adapt eventually. had these migrations before, looking at you ztimer. compatibility layers might help for that.
  • Martine: to be fair: every migration takes a lot of time
  • Karl: but can be done gradually once unicoap is merged. ztimer also took 3 years
  • maribu: disagrees that unicoap was developed openly. tracking issue, then huge PR that was not reviewable. small steps PRs starting from nanocoap would have been possible to get whole community on-board
  • carl: 1) was a thesis, not enough time to make all small-step improvements. 2) IMO source-breaking changes should be as minimal as possible to be user-friendly
  • Martine: changes to existing codebase always bear the question of sunken cost, when a lot of source-breaking changes need to happen that might be already the case
  • Karl: initial port of ztimer: 57 files changed. developing a new API in the open is already more hassle, so I understand that it makes sense to not develop fully in the public
  • Ann: unicoap was officially a Bachelor thesis, we cannot ask for more development in the public IMO
  • carl: comment on “unreviewable PR because of size”. maybe not reviewable in a given time. but adding a new subsystem will always be non-trivial.
  • Teufelchen: I had the feeling that the development was quite public, but I am biased since I am at HAW Hamburg. If maribu does not agree with that feeling, we should try to understand what we could do better for future projects. not something for this meeting, but carl and maribu could sit together at some point and try to find points to improve the process for the future.
  • Ann: should we have the discussion now?
  • maribu: first step would have been to have a small first PR with serializing
  • carl: we had that
  • Teufelchen: we need to first hear out maribu, lets not start discussion on what’s past
  • maribu: the PR was too big for me to review (already included all options accessors), asked it to be reduced, that did not happen. it is okay, but if I do not get involved I will also not be fine with someone taking nanocoap away from me
  • Ann: maybe I misheared, didn’t sound like it to me (people taking nanocoap away)
  • maribu: we can have that discussion when unicoap can cover our use-cases
  • Mikolai: When time comes, please provide these use cases. you may start from the list above
AOB
Hello everybody!
2026-08-07T13:00:00Z we will have our next weekly coordination meeting.
Best
Martine
RIOT weekly coordination 07.08.2026, at 15:00 CET
Link: Jitsi Meet
Attendees
  • Tri-State Tom
  • Ann​:frog:
  • maribu
  • Karl
  • Teufelchen
Note-takers
  • Moderation: Anarchy :bomb:
  • Notes: Maribu & Karl
Agenda
  • Release stuffs
  • Streamlining Security Reports
  • Streamlining Release Process
  • Failing nightly :sleeping_face::bomb: & weekly
  • RIOT, CI and you (HiL, SiL, I am in a loop :clockwise_vertical_arrows:)
  • Github PR Stacks
Notes
Release stuffs
  • Things are not really progressing…
  • Tom: Release have been halter for some time. Two major problems left
    1. Interop Test spec 8 task 8 that has been failing since last release. Probably not complicated, but lack of time to fix. Easy to reproduce, passes in 2026.01, so bisecting is possible
    2. The LoRa one. Not sure about this one. Jose tested a bit, not easy to reproduce. Hardware access is limiting me to address this.
  • Ann: Since you did not volunteer to manage the release, we hardly can ask you to fix this.
  • Tom: But I cannot move the work to Michael
  • Ann: But Michael at least volunteered. It should also be fine to just document the regresssions and ship.
  • Tom: I don’t want to slip on quality here. Release should be reliable and RIOT should be getting better, not get worse over time. Maybe I’ll throw some Tokens on it and see if that helps.
  • maribu: try delegating
  • Tom: Tried, but to no avail. Everyone is busy or has moved on.
  • Karl: On what setup fails it
  • Tom: Running reliable in the FIT IoT Lab testbed for 2026.01, but fails reliable for the RC
  • Ann: Was already failing in the last release spec, wasn’t able to dig depper due to time constraints
  • maribu suggested to remove the security mailing list and use Github security advisories exclusively
  • maribu proposes that the email security@riot-os.org could just auto-reply with instructions on how to use the GH SAs
  • Room: test HackerOne
  • maribu: For compliance reasons, it is good if commercial users base on a release rather than on master, as mandatory vuln management is easier: The “affected versions” field ususally is in terms of releases, not in terms of commits
  • maribu: For compliance reasons, it is good if all security related fixes get backported into a release
  • Ann​:frog:: Release process is already draining a lot of resources. There is little potential increase the frequency without negatively impacting development.
  • maribu: Maybe we should revisit the release process and see, how we can streamline it to the point, that releases become easy enough to manage
  • Tom: It is always good to have as much automation as possible, but it is not easy to get good automation. We had a lot of automation done, but maintenace was starting to pile up (e.g. zephyr started to no longer work on hardware we had etc.)
  • Ann: …
  • Tom: Before adding more tests to the release, require them to be automated reliable. Reducing the release tests is not a good idea, it should rather grow to improve coverage and cover new features
  • Karl: just Patch backport ?
  • Tom: release branch
  • Tom: We did point releases with limited testing by deducing what actually could be broken by the delta
  • Ann: releas usage?
  • Karl: kindof for us ( like to do more )
  • Tom: definently
  • Ann: less releases
  • Maribu: even more relprocess break
  • Tom: hunting for checkmarks
  • Ann: we are missing time – maybe revaluate at summit
  • Tom: any objection to bring it up ?
  • Room: silent No
  • Ann: putting it to agenda
Failing nightly/weekly :sleeping_face::bomb:
nightly
  • maribu: previous failure mode was one test on samr21-xpro failed when compiled with LLVM. New failure mode is timeout until crasbe kills it
  • github flaky
  • ci depend on crasbe
  • 7h
  • Teufelchen: split up ci to not make less fail at once
  • Tom: sub tests kinof exist
  • maribu: need more details
  • Teufelchen: multiple murdocks
  • maribu: splitup might not work
  • Tom: might be configurable
  • Room-disq: some split might be posible an helpfull
Weekly
  • Tom: The output is not easy to understand. Poor signal to noise ratio. If we were able to highlight what the actual issue is (Github runner flaky, connection to FIT IoT Lab flaky, actual issue) would help
  • crasbe: Idea: Could we have a Docker image for HiL clients based on tinybuild to make the setup less of a pain?
  • crasbe: (yes, looking at the whole Docker situation is on my ToDo, we also need to update the Ubuntu version soon(ish))
  • Ann: simplify industy soulution
  • maribu: the task is not that easy
  • Ann: maybe i should try
  • Tom: been though that
  • Teufelchen: build something to get positive responses
  • Tom: id like to offer some experience
Github PR Stacks
  • Ann​:frog: (on Matrix): Talking about it PR review, they finally added a fairly neat feature that other git forges had for a while, you can finally stack PRs to make them more readable / chunked
  • maribu: The feature requires admin intervention to enable. @maribu and @basilfx have PR stacks ready to submit. Would like to try it to see if it helps managing reviews or dependend change sets.
Hello everybody!
2026-08-14T13:00:00Z we will have our next weekly coordination meeting.
Best
Ann :left_speech_bubble::frog:
RIOT weekly coordination 14.08.2026, at 15:00 CET
Link: Jitsi Meet
Attendees
  • Karl
  • Crasbe
  • Ann
  • Tri-State Tom
  • Lasse
  • Teufelchen
Note-takers
  • Moderation: Anarchy :bomb::fire::firefighter:
  • Notes: Tristate Tom, Ann​:frog: & Friends
Agenda
  • Assessment of the Rust integration of RIOT
  • Build System/CI: Introduce Build Variants
  • riotdocker update to Ubuntu 26.04 LTS :raccoon:
  • Release Update
Notes
  • maribu: The rust integration of RIOT is causing a lot of maintance effort, because
    • interdependent code split over three repos:
      • Parts of the rust infrastructure in RIOT, parts in rust-riot-sys, parts in rust-riot-wrappers
      • often having to juggle PRs between three repos
      • cargo’s patch.crates-io is a footgun: changes to riot-sys need to be patched in both RIOT and rust-riot-wrappers repos, otherwise fixes do not actually get deployed
    • c2rust is not meant to be used to provide a stable interface: it targets a “fire and forget” conversion of a C codebase
      • updates of c2rust often break rust-riot-sys
      • changes in C code that are extremely unlikely to break any C code users (e.g. converting a function argument from char * to const char * or to const void *) do reliably break rust-riot-sys
    • rust breakage often taking a “PR hostage” by virtue of a failing CI
      • specialized knowlege and skills needed to fix
      • a single line change in C code that is extremely unlikely to break C call sides has a tendency to burn half a work day on the rust fallout
  • maribu: mixed stories about success of rust integration
    • there were initially some public examples for use of rust in RIOT, maybe worth checking out what happend
    • tests of writing rust code for RIOT at my employer were rolled back to C code, as crucial C APIs were not available to rust
  • maribu: Maybe it is time for a sober cost-benefit analysis to see if the current approach is sustainable
  • maribu: Possible options forward:
    • double down on rust
      • stakeholders agree to allocate some serious person hours on this
      • move rust into the RIOT repo, so that the public rust API becomes the stable interface, not how c2rust interprets C code
      • phase out use of c2rust
      • expose more RIOT APIs as rust interfaces
    • move rust support out of the RIOT repo
      • no more failing CI taking PRs hostage
      • high risk that rust integration will not be maintained adequately and depend on old RIOT releases for ages
    • drop rust support entirely
    • accept the maintenance cost and continue with the current approach
Ann: Maribu not here, would make sense to at least wait for Chrsyn
Ann: Hard to understand the how to even get the rust PRs running
crasbe: You need to update in the right order in order to test.
Ann: We should discuss this at the summit, since it has long term impact on the future of RIOT (Also discussing without Chrsyn is wack)
Karl: Rust stability issues, does anyone know about C2rust? What about const vars, how it treats them so on? ignore const in headers when c->rust might yield more flexible rust c integration
Group agrees that we have no clue about this
Action Point: Add to summit agenda
  • crasbe: prepared RFC: build system/CI: Support for Build Variants ¡ Issue #22555 ¡ RIOT-OS/RIOT ¡ GitHub
  • crasbe: Many tests/examples have configuration options, but only one variant is ever built.
    • Can lead to bitrot
    • Especially when code paths are guarded with #ifndef ...
  • crasbe: Build Variants Support:
    • Introduce an additional Makefile.variants.ci that includes environment variable settings for different variants
    • Read by CI script(s), added to job list
  • crasbe: Tribal Knowledge required: where to add the code for the CI side?
    • RIOT-OS/RIOT/.murdock?
    • RIOT-OS/murdock-scripts?
    • Both?
crasbe: At least Kaspar or maribu should hopefully know this, both not here :frowning:
Tom: Maybe you can ping Leandro or José, they should have experience from past stuff multiplication of builds can be iffy when testing more stuff Used to be on mobi, now tatooine, when something updates it will be updated there Not sure whether its automatic, remember “watchtower” that updates the docker image for runner
crasbe: Appears to not be part of that repository, not sure whether guarded by watchtower, not aware of repository that might host it
Tom: Tough, back when ??? did React stuff
Teufelchen: I have access to that repository
Tom: There was discussion how you can add different configs into different job queues prev. how we solved, different tests with different makefiles Would add to tests, copy everything but makefile/super, was dirty
crasbe: Maybe if you have time, look at my proposal :wink: Have configuartion makefile that gets set before application makefile Dont have to do any copying, deep changes, simple additions to job scripts
crasbe: Would like to have idea where to look, everything really really complicated
Karl: I think Murdock gets variances by calling makefile info commands, very overengineered/stretched
Tom: Looking through Murdock scripts right now, uggh, maybe instead of sep. jobs still have one for caching
Karl: We have internal potential solution work right now (no esp for now tho) Murdock is already quite full (queue), maybe not increase too much but also want more stuff to be tested
Teufelchen: Agrees, Murdock has problems Karl: Might also be our build system and Murdock just has to fight against it
Teufelchen: Not directly my problem with Murdock, biggest problem is nobody understands Murdock, nobody knows how to do anything with it
Crasbe: Variants would not increase build time by 2x over night, maribus work to make caching better could mitigate this Proposal should/is also compatible with most other build systems
Agree to move on since we need more input from other people like Kaspar
Release Update
  • Tom: Tacking on, release backporting right now, doing RC2 right now Will make clear that some release tests had issues Hopefully should warn next release manager
  • Ann: Just put in RIOT issues, worst case warn next release manager again when they start working
Hello everybody!
2026-08-21T13:00:00Z we will have our next weekly coordination meeting.
Best, Mikolai
