I’m using RIOT OS to run a LoRa (PHY only) application. I am trying to upgrade to the 2018.01 release, but, after making a few small changes to get the code to compile, LoRa packets are no longer sent - nothing goes out on the air after calling send.
I have a saml21 mcu, an sx1272, and a custom board. Is there anything new in particular that needs to be done to use LoRa with the 2018.01 release?
Thanks for your reply. I was able to send messages successfully on the master branch by tweaking the params in sx127x_params.h.
I’ve since run into another issue. I’m now on the the master branch of RIOT, testing with a nucleo-f411 and an mbed sx1276 LoRa shield. When I run the test in pkg_semtech-loramac, I can only receive data confirmations if my data rate is 2 or higher (faster), but I would like to use a data rate of 0 (slower).
