Hi Gaetan
I would like to introduce some packaging concepts around RIOT. To consider modules like well defined distribution packages and not only source files added to an application firmware.
From what you're saying, I understand that the aim is to make modules
completely self-contained with respect to build definitions, and make those definitions much more human readable. In this way, an application developer can go to only one place to find out information regarding a module's build (dependency information, etc.), and a module developer only has to write/change the module directory Makefile and can do so with declarative language. Also, the information can be easily parseable for eg a user interface.
So the changes you're proposing are:
1) Move build information concerning a particular module into that module's Makefile 2) Make the module makefiles able to be written with purely declarative language 3) Retain backwards compatibility with the current build system
Is this correct?
I think 2) would be great for user friendliness, and 3) is a no-brainer. 1) is a bigger topic as there are a number of different ways in which dependencies are manifested for example, so I think this can be a point for further discussion... do you have any particular examples?
Dan.
