Hi together,
Is there a way to get rssi programmatically from a received package over UdpSockApi “sock_udp_recv”?
I read almost everything twice on the documentation but I couldn’t find anything about the communication quality as a variable or as a function.
Best Regards,
Kemal
Hi Kemal,
sadly there is non. You have to use gnrc_netapi
[1] instead then (it’s what is used by sock
underneath when you are using GNRC) [1]. The RSSI of a packet is stored in it’s GNRC_NETTYPE_NETIF
header [2]. Hope that helps.
Martine
[1] http://doc.riot-os.org/group__net__gnrc__netapi.html
[2] http://doc.riot-os.org/group__net__gnrc__netif__hdr.html
Hi Martine,
thank you very much for the hint. I was really helpful. Now I’m able to dump the RSSI.
Best,
Kemal
