Hi All,
I am trying to use Riot for an internal project.
I have tested Riot on native. I am stuck on the STM32F0-Discovery, which I expected to be pretty stable. I have the latest code from the repository.
I have flashed the STM32F0-Discovery board with make flash utility, based on the instructions given at https://github.com/RIOT-OS/RIOT/wiki/Getting-started-with-STM32F%5B0%7C3%7C4%5Ddiscovery-boards
I got the following output from openOCD, which seems normal enough to me.
/media/linux-space/anand/Work/IoT/riot/RIOT/dist/tools/openocd/openocd.sh flash
Flashing Target
Open On-Chip Debugger 0.9.0-rc1-dev-00001-gabd7ad0 (2015-04-25-11:22) Licensed under GNU GPL v2 For bug reports, read http://openocd.org/doc/doxygen/bugs.html Info : The selected transport took over low-level target control. The results might differ compared to plain JTAG/SWD adapter speed: 1000 kHz adapter_nsrst_delay: 100 none separate srst_only separate srst_nogate srst_open_drain connect_deassert_srst Info : Unable to match requested speed 1000 kHz, using 950 kHz Info : Unable to match requested speed 1000 kHz, using 950 kHz Info : clock speed 950 kHz Info : STLINK v2 JTAG v14 API v2 SWIM v0 VID 0x0483 PID 0x3748 Info : using stlink api v2 Info : Target voltage: 2.901302 Info : stm32f0x.cpu: hardware has 4 breakpoints, 2 watchpoints TargetName Type Endian TapName State
0* stm32f0x.cpu hla_target little stm32f0x.cpu halted target state: halted target halted due to debug-request, current mode: Thread xPSR: 0xc1000000 pc: 0x0800020c msp: 0x20000b98 target state: halted target halted due to debug-request, current mode: Thread xPSR: 0xc1000000 pc: 0x0800020c msp: 0x20000b98 ** Programming Started ** auto erase enabled Info : device id = 0x20006440 Info : flash size = 64kbytes target state: halted target halted due to breakpoint, current mode: Thread xPSR: 0x61000000 pc: 0x2000003a msp: 0x20000b98 wrote 15360 bytes from file /media/linux-space/anand/Work/IoT/riot/RIOT/examples/hello-world/bin/stm32f0discovery/hello-world.hex in 0.900809s (16.652 KiB/s) ** Programming Finished ** ** Verify Started ** target state: halted target halted due to breakpoint, current mode: Thread xPSR: 0x61000000 pc: 0x2000002e msp: 0x20000b98 verified 14808 bytes in 0.205989s (70.202 KiB/s) ** Verified OK ** shutdown command invoked Done flashing
The board seems to be stuck in reset_handler
Reading symbols from /media/linux-space/anand/Work/IoT/riot/RIOT/examples/hello-world/bin/stm32f0discovery/hello-world.elf…done. Remote debugging using :3333 reset_handler () at /media/linux-space/anand/Work/IoT/riot/RIOT/cpu/stm32f0/startup.c:61 61 for (dst = &_srelocate; dst < &_erelocate; ) { (gdb) p dst
$1 =
The USB to Uart converter has been connected to the prescribed ports TX=PB6 RX=PB7 GND=GND, but is not getting any output, probably because the board is stuck.
I am sure I am missing something pretty basic, but I have no clue as to what it is. The code looks proper enough. Thanks for any ideas on how to move ahead.
regards, -anand
