I hope that i write in a correct place. i am newer on RIOT. I’ve started to learn about it. i amm using “https://github.com/RIOT-OS/RIOT/wiki/Creating-your-first-RIOT-project” as tutorial.
In the mentioned website i used command …/…/dist/tools/tapsetup/tapsetup -c
tap0 and tap1 created successfully. Then i used make and then, ./bin/native/my_project.elf tap0.
the result is:
usage: ./bin/native/my_project.elf [-i ] [-d] [-e|-E] [-o] help: ./bin/native/my_project.elf -h
Options: -h help -i specify instance id (set by config module) -s specify srandom(3) seed (/dev/random is used instead of random(3) if the option is omitted) -d daemonize -e redirect stderr to file -E do not redirect stderr (i.e. leave sterr unchanged despite daemon/socket io) -o redirect stdout to file (/tmp/riot.stdout.PID) when not attached to socket
The order of command line arguments matters. samira@samira-pc:~/RIOT/examples/my_project$
could u please guide me, what is the problem and how can i solve it? thanks for your kind consideration
