I've got a chip which needs precise timing to be read. A year ago, I
was able to communicate with this chip but now, even if I go as fast I
can it seems that timing have increased with same source code.
So is there a way to force the CPU to do only one task at the time for
the duration of the function. Ca
the duration of the function. Can we tell the scheduler to stop other thread?
two things might interrupt:
1. a thread with higher priority
This can be solved by increasing the priority of the thread talking to
your code, possibly to the maximum.
(beware: lower priority value means higher priority)
2. interrupts
If an interrupt messes with your timing, that can be prevented by
disabling interrupts for a time-critical section:
unsigned state = irq_disable()
/* timing critical code */
irq_restore(state);
