I tried this once by setting the RPL_MAX_ROUTING_ENTRIE as 6. The application complied but it didn’t start after flashing the image to the board. I will try do more experiments on this with different routing entry values.
Thanks
Abdul
Hi Abdul,
Thank you. This worked for me. I increased the KERNEL_CONF_STACKSIZE_DEFAULT to 2K to make things works for my application.
I see that we have problems in making rpl_udp application working in SAM R21 due to the RAM limitation. Is there anyway, we can make this work in the platform?
Have you already tried decreasing RPL_MAX_ROUTING_ENTRIES, if that’s possible for your network size?
I observed another problem, when using sixlowapp with SAM R21. I have 3 sam r21 boards. I flashed sixlowapp in all the boards. When I start the boards, one of the node freezes but other two nodes can exchange data using nc command. Any of you observed this problem before?
Just yesterday I learned that there is probably a bug in the SPI driver that
may cause this problem. Maybe Hauke can tell more about this issue.
The changes in that branch is so massive that I have no clue what have been
modified... Some are regular fixes but others are ugly hacks.
Perhaps an PR after rebase could bring some of the fixes to your attention?
In an ideal world, you could try to make a PR for the single fixes. But in
case you currently don't have the time for this, a unified PR marked as WIP on
a rebased branch could be a good starter indeed. Maybe I or someone else can
find some time, trying to create single PRs from your fixes then.
I'm truly sorry about my absence of late. I have started in a new
engineering job that takes pretty much all my time...
No need to apologize, we all have to work from time to time.
I fear I can not really help, aside from telling you that I have just taken on the work to fix the radio driver. I hope I will be able to pull request a fixed version next week… Cheers, Hauke
