Hi All,
Recently I started using RIOT on my sam r21 xplained board. When I tried to ping between two boards running the sixlowapp application, the application hangs and I need to reset the board to continue working. Can anybody help me to understand it is so?
The log below is taken after enabling debug in ip.c, icmp.c, sixlowshell.c, monitor.c, helper.c, lowpan.c
Node 1 (source from ping initiated)
Hi Abdul,
The ping issue should be
fixed by applying https://github.com/RIOT-OS/RIOT/pull/2727. The next problem
you might run into with the sixlowapp is that the stacksize settings for the
SAM R21 board are currently a little conservative, which causes it to run out
of memory when trying to send a UDP packet with the nc command of the sixlowapp.
This can be “fixed” by increasing the KERNEL_CONF_STACKSIZE_DEFAULT in
RIOT/cpu/samd21/include/cpu-conf.h - I’ve got it to work by increasing it to
1536, but you might have to play around a little.
Lucas
