Dear Thomas,
Thank you for your feedback, see my response inline below.
Dear Joakim,
I would like to have a separate driver for setting up the CPU pin mux.
That is, separate the CPU logic module drivers (such as SPI, I2C, UART
etc.) from the actual hardware ports and pins.
You mean introducing a central point to handle all the PIN initialisation for
the other peripherals? “Mux-driver, initialise pins for UART3!”
I would expect that reconfiguring pin function muxing in the middle of
a running application would be a quite uncommon use case, so I would
expect something like during board init, I would call something like
"Mux-driver, initialize all pins according to board config X". And
then the module drivers would not need to worry about which signal
goes to what pin, only generating the signals.
By improving the separation/abstraction it may make it easier use the
same board directory for multiple variations of the same board, where
the on board peripherals are the same, or almost the same, and only
some minor additions.
I see your point here, but couldn’t it be realised by using some different
configuration in periph_conf.h separated by preprocessor guards? Like:
#ifdef MULLE_v1
#define SPI0_MISO_PIN PA12
#elif MULLE_v1.2
#define SPI0_MISO_PIN PB09
#endif
Yes, I guess you are right about the preprocessor conditionals, but
there are some applications where you may want to configure something
only a tiny bit different, e.g. rerouting the debug UART to another
pin in the RPL border router, to let the default UART only handle SLIP
traffic, and connect an extra UART cable to your PC only when you need
the debug output. It is of course achievable by the traditional model
as well, but if I know that all pin configs are done at a particular
moment, and according to the config, then I do not have to worry about
in what order I initialize drivers.
Because of the hardware function muxing capabilities in advanced MCUs
is usually in a separate module it is only logical that the driver for
a CPU module does not need to know anything about which pin numbers on
the IC is connected to its signals, the driver should only control the
logic within its own module.
The peripheral interface currently tries to exploit the greatest possible
common set of functionality while minimising overhead. Since such a mux-driver
would mainly be used in the other peripheral drivers it could be optional.
Also it would need evaluation of the impact on more constraint platforms
(cortex-M0 etc.) in terms of memory and clock rate.
This is kind of a board/cpu software architecture design decision, I
am merely looking for merits and deficiencies with this model.
The main point of splitting it up is a logical division of
responsibilities between software components. Since the pin function
mux is its own hardware module it is only logical that it has its own
driver, instead of letting all other drivers poke around inside it at
will. Every driver in the current implementations is designed to
handle its own hardware module, except it has to touch the pin muxing
as well. Every driver also does basically the same thing during
initialization, which means code duplication and risks for
copy-and-paste errors or code rot. The outline of most drivers' init
functions is:
1. Enable clock gate to I/O port/pin
2. Set pin mux to correct choice.
3. Enable clock gate to CPU module
4. Initialize CPU module configuration registers.
The main change would be that steps 1 and 2 are handled in a central
place => possibly less ROM usage.
I like the idea in general but could you elaborate a little bit more on the
concrete use case and implementation so we can discuss this in more detail.
I don't have an implementation yet, still working on the best approach
to do it, and whether it is a good choice, hence this thread.
Best, Thomas
Joakim Gebart
Eistec AB
www.eistec.se
