Hi RIOT users,
I created a network with several nodes that communicate using RPL and UDP in native.
It works well. Thansk all for your work.
But I was wondering if I can use this code on platforms as for example on Zolertia. But I can’t build my code for Zolertia board as I get an error saying “region ‘ram’ overflowed” (same for region ‘rom’).
Is my code not adapted to small platforms or is it due to the implementation of the network stack in RIOT ?
I can see in the branch master that you have done a lot of new improvements on networking (ng_*) but as the example in examples/ng_networking is described for RIOT native, is it possible to use the same kind of things for Zolertia or other platforms ?
Thanks a lot for your help, I am a little lost
Caroline QUEVA
Research Engineer at CEA-LIST
DRT/LIST/DACLE/LIALP
Laboratoire Infrastructures et Ateliers pour le Logiciel sur Puces
Commissariat à l’énergie atomique et aux énergies alternatives
MINATEC Campus | 17 rue des Martyrs | 38054 Grenoble Cedex 9
Hi Caroline!
Zolertia. But I can't build my code for Zolertia board as I get an error
saying "region 'ram' overflowed" (same for region 'rom').
Actually making things more memory efficient was one of the motivations to
start work on the new network stack. In general, we're aiming to make it
possible to run an RPL/UDP application on smaller platforms such as the Z1,
too. With the old network this is difficult, if not impossible, and manual
tweaking all over the place is required.
I could give you some advices where to save some memory, but my recommendation
is: wait until the end of this week and use the new (gnrc) network stack.
We're about to merge the porting of RPL to gnrc this week (see
https://github.com/RIOT-OS/RIOT/pull/3050). (Thanks, Cenk, for the great
work!)
As I wrote: yes, that's definitely intended and we're optimistic to get the
full new stack ready and stable by the end of this month.
Oleg
