Hello Ichrak,
Thanks for the feedback!
I will try to look into this matter, I am currently at work though.
Yesterday I tested the RPL-UDP example on native and on two msba2s and I
did not see any error. Unfortunately, I have no IoT-LAB hardware to do a
specific test on those ones. Maybe someone @University can have a look at
it, too. I will be at the university tomorrow and hopefully I can find
some IoT-LABs there.
- Could you provide me with a backtrace of your
crashing
nodes?
- are you using the storing or nonstoring mode?
- do you specify the
routing entries size
explicitly at compile time?
Best,
Cenk
Hi Cenk,
I don’t know of you can run tests via the IoT-LAB portal,
I used the serial_aggregator (https://www.iot-lab.info/tutorials/nodes-serial-link-aggregation/)
in frontend to access serial traffic of M3 nodes, or simply netcat port=20000.
(I have just shared the tutorial link)
- at some nodes, after the ‘init n’, (and the ‘init r’ at the root), these nodes do not respond to any command:
m3-3;dodag (--> nothing)
m3-4;dodag
m3-5;dodag
For another node which cannot join the dodag:
Hi Cenk,
I don't know of you can run tests via the IoT-LAB portal,
Note: IoT-LAB is an open testbed, so anyone can subscribe and run tests on
this platform
Best,
Emmanuel
