Hi Alessandro,
Hi Sebastian, Sorry if i disturb you, but i had follow the tutorial for:
• Create a 6LoWPAN Raspbian image • Spice up Raspbian for the IoT
SCENARIO Now i should be able to query, from the Raspberry PI 3, my SAMR21-XPRO running a RIOT microcoap server ( with global address) On my PI i've plugged a OpenLabs 802.15.4 transceiver, from pins 15 to 24.
NOTE : Following the 1 tutorial, i didn't found the /boot/overlays/at86rf233-overlay.dtb
But when i run the coap-client command on PI it gives me back this error:
root@raspberrypi:/home/pi# coap-client -m GET coap://[2001:db8::1]/.well-known/core v:1 t:CON c:GET i:0b38 {} Jun 23 18:24:30 CRIT coap_send_impl: Network is unreachable
How can i fix it? Thanks a lot.
You should debug this problem step-by-step, starting with COAP right away might not be the best way to begin with.
Assuming you followed the 2 guides above carefully, you should see a `wpan0` device running `ifconfig`. This is how it looks on one of my RasPis:
$ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:03:64:bd
init addr: Bcast:www.xxx.yyy.zzz Mask:255.255.255.0
inet6 addr: fe80::8099:426e:ba8e:3652/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:2765151 errors:0 dropped:21 overruns:0 frame:0
TX packets:216917 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:194526990 (185.5 MiB) TX bytes:40495510 (38.6 MiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
inet6 addr: fd9a:1234:5678:0:ba21:5b58:d2b2:79b8/128 Scope:Global
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
lowpan0 Link encap:UNSPEC HWaddr BA-21-5B-58-D2-B2-79-B8-00-00-00-00-00-00-00-00
inet6 addr: fd9a:1234:5678:0:b821:5b58:d2b2:79b8/64 Scope:Global
inet6 addr: fe80::b821:5b58:d2b2:79b8/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1280 Metric:1
RX packets:33549 errors:0 dropped:0 overruns:0 frame:0
TX packets:133498 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:2130027 (2.0 MiB) TX bytes:13887785 (13.2 MiB)
UP BROADCAST RUNNING NOARP MTU:123 Metric:1
RX packets:33995 errors:0 dropped:0 overruns:0 frame:0
TX packets:133645 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:300
RX bytes:931713 (909.8 KiB) TX bytes:13604264 (12.9 MiB)
You also see a `lowpan0` device already configured above -- but the important thing is that `wpan0` **must** be visible. Otherwise the OpenLabs transceiver failed to init or the driver is not loaded. You can also check with the wpan-tools run `iwpan list` you should see some detailed info.
If `wpan0` is missing, check that you enable the overlay in `/boot/config.txt` [1], further the overlay itself must exist in `/boot/overlays/at86rf233.dtbo`. If the latter is missing you did not follow the description [2], maybe you forgot to copy the files to the SD card like this:
sudo cp arch/arm/boot/dts/overlays/*.dtb* <path/to/boot-mount>/overlays
If you see `wpan0` but `lowpan0` is missing, run `sudo create_lowpan 26 "0x23"` (assuming you have installed my helper scripts [3]).
I suggest you try to get this working first. When you have a `lowpan0` interface up and running on the Pi you can proceed -- try the RIOT gnrc_networking example [4] first, before diving into COAP.
Cheers, Sebastian
[1]: Create a generic Raspbian image with 6LoWPAN support · RIOT-Makers/wpan-raspbian Wiki · GitHub [2]: Create a generic Raspbian image with 6LoWPAN support · RIOT-Makers/wpan-raspbian Wiki · GitHub [3]: Spice up Raspbian for the IoT · RIOT-Makers/wpan-raspbian Wiki · GitHub [4]: RIOT/examples/gnrc_networking at master · RIOT-OS/RIOT · GitHub
