Based on the specs/requirements on the riot website, the board I have is right near the edge of support. I'd like to know what you guys think. Would I--with some adapting of the code for the ATmega and the radio chip--be able to run a 6LoWPAN / RPL / UDP stack on a Freakduino 900 MHz LR ( ATmega328P 32K flash, 2K RAM, AT86RF212 )?
The applications for this would be a simple relay node or (at most) routing UDP packets (small enough that fragmentation isn't necessary) via the serial port.
thanks,
!!Dean
