due to an immense load of requests on the mailing lists, ten thousands of
mails got queued over the last days. This lead to a delay for mail delivery up
to several days. After some throttling and performance tuning on the mail
server everything should be back to normal and most of the mails should have
been delivered by now.
Sorry for the inconvenience and please let me know if you encounter further
problems.
Just out of curiosity, was this due to a lack of machine resources?
How is RIOT's infrastructure (e.g. web and mail hosting) handled; is
the hosting donated by one or more of the supporters listed at the
bottom of the project's homepage? Would additional hosting resources
be helpful?
Actually not. In fact, the maximum number of MTA and content filter processes
were configured too low.
be helpful?
Currently, some of the services (e.g., web and mail) are hosted privately by
community members, other services are sponsored by supporting institutions
such as FU Berlin, HAW Hamburg, and Inria. In general, additional resources
are always helpful, particular for the CI system, I guess. Do you have
something particular in mind?
I was going to suggest that you might talk to the Oregon State
University Open Source Lab (http://osuosl.org). OSUOSL offers free
hosting, email, VMs, colocation, FTP, backup, etc. (both managed and
unmanaged) to open source projects. I can't speak to what type of
computing power they offer but I know they've been working to stand up
an OpenStack cluster they may be able to help out with CI or in other
ways.
I'm not affiliated with OSUOSL, I just live in their area.
Thanks for the pointer. That's definitely something we should consider.
Oleg
ways.
They also offer to host a server of your own. We do that for the Enlightenment project for several years now. Their connectivity and general admin service has worked very well for us.
We have a beefy server there hosting our own tons of git repos, web services, downloads, CI, etc. I don't think there is any bandwidth limitation or such. All in all a really nice service from them to the open source communities.
If it is something interesting for RIOT I have no idea but if you are looking for something in that regard it is surely worth talking to them.
Oleg
ways.
regards
Stefan Schmidt
To offer an alternative, I can offer the services of Studenten Net
Twente[1]. Studenten Net Twente is a student associations of the
University of Twente aimed at providing IT services. We have a history
of supporting open source projects by offering FTP space and/or
colocation services for free.
As we use RIOT-os for an internal project, we'd love to return something
to the project. If a host for CI or other services is needed, I can see
if I can get a virtual machine or some real hardware available for
RIOT-os infrastructure.
What sort of hardware would RIOT need for CI? Would a machine with,
for example, a pair of E5-2670 (eight cores @ 2.60 GHz), Xeons between
64 and 128 GB of DDR3 ECC RAM, an SSD or two, and maybe some spinning
storage suffice or are we talking about something like a highly
available cluster consisting of half-dozen or more HP ProLiant DL380
Gen10 machines each with a pair Xeon 8100s (28 cores @ 3.60 GHz), a
terabyte of DDR4 RAM, and a pile of blazing fast NVMe drives?
I'm just thinking that if a machine or two with specs closer to the
first example would suffice than I imagine the RIOT community might be
able to find a way to make it happen.
A word of warning… While I'm absolutely serious about trying to help
out in this area (and other) please know I'm currently trying get the
ball rolling and determine what type of resources the project could
most use; it'll take a bit of time to turn these early thoughts into
something real. Personally, I may not have piles of cash laying around
but I do have something else of value, time.
Having just done something similar for something else, you should really look at doing CI in AWS lambda. It is remarkably cheap and (more importantly for my case) requires nearly zero devops once set up. If you suddenly have 10x the CI runs, they can all run in parallel for the same cost. No queues.
The CI can take advantage of anything with 4g of RAM for the ccache and
another .5g of RAM per core. Long-running is preferable, as the ccache
takes a couple of builds (or a manually triggered full-build) to warm up.
We currently have 2 16-core (Dual Xeon E5-2660/2670), 2 20-core (don't
know which Xeons) and a couple of Quad-Cores. There are also about 20
dual-core VM's on the Inria CI cluster, but they're down at the moment.
See e.g., the bottom of [1] for the relative performance of these boxes.
We decided (inofficially) on a build target time of <5min to be
acceptable, which we're below if the Inria boxes are up. But with every
test or every new supported board, the build matrix grows...
I doubt that setting up quad core boxes are worth the administrative
overhead (which is basically setting up a systemd service keeping a
docker container running), but if you could spare dual 8-core Xeon
boxes, that would be nice.
The boxes mostly idle, and as everything runs in RAM, even if a build
starts, e.g. on my quad core workstation, I barely notice the builds.
cost. No queues.
I'm not sure the current RIOT build system requirements match AWS lambda
in order to properly make use of it.
For every build, the current CI sends "build application X for board Y"
as job to a CI queue. With git workdir caching and most of the build
already in ccache, such a job takes between .5 and 2 seconds. Without
those caches, more like 10 to 20 seconds, depending on the time needed
to check out RIOT and to a cold-ccache build. If I understand AWS lambda
correctly, it is not really suitable if that much context information is
needed.
I was looking into using AWS and the google container engine, but
without the caches (e.g., on freshly booted containers/VMs/instances),
they're not very attractive performance wise. Long-running (keeping the
caches in memory, or even using the persistent storage options), they're
not attractive price-wise.
You can do anything that takes less that 300 seconds, so that is ok. The biggest thing that I like is that you pay only for the time spent servicing requests, but the lambda actually persists between requests (for free) so you can store data on the hard drive (up to 500MB) and you can keep data in memory. The only caveat is that AWS can remove that whenever they want, but in my experiments it lasts several hours. So for the CI use case I would basically configure the lambda image to contain a recent-ish workdir, then update it in the invocation (so if it being reused the update will be a noop).
So yeah, totally agree that you need caching, but actually it does that, they just don’t advertise it much.
