Hello everyone,
I started to pull the latest RIOT release (actually it's the latest master for now) into my local repo that has my own board in it. However, after merging I am not able to run the default example. I had this problem several months ago but I cannot recall how I solved it. The problem is that the message queue (msg_array of the thread) is NULL and thus the netreg throws an error here.
2017-06-14 10:42:13,172 - INFO # main(): This is RIOT! (Version: 2017.01-devel-2165-g39e9b-rhpc-hartung/boards/inga) 2017-06-14 10:42:13,188 - INFO # sys/net/gnrc/netreg/gnrc_netreg.c:49 => n/a 2017-06-14 10:42:13,203 - INFO # *** RIOT kernel panic: 2017-06-14 10:42:13,204 - INFO # FAILED ASSERTION. 2017-06-14 10:42:13,204 - INFO # 2017-06-14 10:42:13,257 - INFO # pid | name | state Q | pri | stack ( used) | base | current 2017-06-14 10:42:13,302 - INFO # - | isr_stack | - - | - | 128 ( -1) | 0xffff | 0xffff 2017-06-14 10:42:13,350 - INFO # 1 | idle | pending Q | 15 | 128 ( 66) | 0x187c | 0x18b9 2017-06-14 10:42:13,396 - INFO # 2 | main | running Q | 7 | 384 ( 322) | 0x18fc | 0x1a39 2017-06-14 10:42:13,444 - INFO # 3 | pktdump | pending Q | 6 | 384 ( 66) | 0x1aee | 0x1c2b 2017-06-14 10:42:13,492 - INFO # 4 | at86rf2xx | pending Q | 2 | 256 ( 66) | 0x1cb1 | 0x1d6e 2017-06-14 10:42:13,523 - INFO # | SUM | > > 1280 ( 520) 2017-06-14 10:42:13,523 - INFO # 2017-06-14 10:42:13,523 - INFO # *** halted.
Has anyone encountered this issue or can tell me when msg_array of the thread is initialized? Is this a CPU problem or a board problem?
Best Regards and Thanks, Robert Hartung
