I have an issue while running the peripheral_spi test example with the STM32F401 Nucelo board. I have made the hardware connections as per the peripheral configuration file and tried to run an SPI loopback test. However, I receive only 0x00 instead of any character that I transmit on the MOSI pin.
The connections that I have made are: MOSI pin (Port A_7) connected to the MISO pin (Port A_6)
Can someone help me out with this issue?
Thanks, Niharika.
This message contains confidential information and is intended only for the individual(s) named. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this mail and attached file/s is strictly prohibited. Please notify the sender immediately and delete this e-mail from your system. E-mail transmission cannot be guaranteed to be secured or error-free as information could be intercepted, corrupted, lost, destroyed, arrive late or incomplete, or contain viruses. The sender therefore does not accept liability for any errors or omissions in the contents of this message, which arise as a result of e-mail transmission.
